Failed FSP300-60BT
  • martincregg
    • Apr 2009
    Failed FSP300-60BT
    Cannot find the exact model at Newegg, but they do have a FSP300-60ATV. Do you know if I can use this as a replacement?
  • Wizard
    • Mar 2008
    • 2296
    Re: Failed FSP300-60BT
    Buy a *Retail* Seasonic 380W PSU.
    Cheers, Wizard
    • gdement
      • Jan 2007
      • 690
      I'm going from memory but I think your old model is a 3.3v+5v oriented PSU. If so, then that replacement looks fine.
      Compare the ratings on each rail, and compare the combined wattage ratings for 3.3+5.
      • yanz
        • Nov 2004
        • 910
        I'm afraid it will have the same failed fuhjyyu/jamicon caps. Better try another brand like mentioned above (300-400W PSU).
        days are so short when you actually do something..
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
        • keldeo
          How many of you have seen failed Panasonics!?
          by keldeo
          In my experience, I've seen failed Taiwan/Chinese caps, obviously as I'm sure all of us had. I've also seen the defective Nichicon and Chemi Con series. Even seen failed Rubycons (MBZ I think?) if they are exposed to a lot of stress and heat. I've never seen failed Panasonics until now! Not just one, but 3! Also in seemingly random locations on the motherboard. Next to the RAM and CPU, but not t part of the VRM. It felt like I spotted a Unicorn, so I had to make this post. Motherboard is a IPIBL-LA. OEM from HP.
          Unfortunately, I do not know the history behind this PC, it also had...
          11-22-2025, 02:36 AM
        • Byte_76
          Understanding capacitor ratings
          by Byte_76
          Hi, I have some capacitors that I need to replace on a graphics card.
          I've attached pictures for reference.
          Please help me to understand the ratings so that I can order the correct replacements:
          1. G7 560 2.5E - I believe these are for vcore
          • Is this 560uF and 2.5V?
          • What does the "E" mean?
          • Is there any relevance to the "G7"
          2. ECX 17 560 2.5V - I believe these are on the memory phase
          • Another 560uF at 2.5V?
          • This is on the same graphics card. If the caps are rated the same as those above, why are they a different type?
          05-10-2024, 07:56 AM
        • survivalbloke
          MacBook Pro 13" Touchbar, model A1706 - Critical software update failed
          by survivalbloke
          This machine came in with a no power complaint after a liquid spill. The only damage I found was on the two USB-C boards, so I replaced those, and the machine charges and fires up. However, if the internal LCD is connected to the logic board, when it boots, I will get a critical update failed warning and the only options are to shut down or try again - it's a loop. I am able to start up fine in safe boot. If I disconnect the internal LCD, I am able to boot normally to the OS. The customer doesn't want to invest any more money beyond what I already charged. Unfortunately, based on what I...
          11-21-2025, 01:12 PM
        • Zarithya
          Lenovo ThinkPad X1 Carbon 7th gen not booting after failed BIOS update
          by Zarithya
          I have a ThinkPad X1 Carbon 7th gen that stopped booting after a failed BIOS update. There is no life from the machine when the power button is pressed, but when the charger is plugged in, the amber charging indicator turns on and the power button blinks three times. The battery does charge, eventually turning the amber light white. I've dumped the BIOS and tried to fix it (but I don't know what I'm doing or how to use Lenovo's update files in this way) and even attempted to overwrite it with other uploads I've found here to no avail. I've posted the dump in the request forum and...
          11-02-2025, 06:26 AM
