Failed FSP300-60BT
  • martincregg
    • Apr 2009
    Failed FSP300-60BT
    Cannot find the exact model at Newegg, but they do have a FSP300-60ATV. Do you know if I can use this as a replacement?
  • Wizard
    • Mar 2008
    • 2296
    Re: Failed FSP300-60BT
    Buy a *Retail* Seasonic 380W PSU.
    Cheers, Wizard
    • gdement
      • Jan 2007
      • 690
      I'm going from memory but I think your old model is a 3.3v+5v oriented PSU. If so, then that replacement looks fine.
      Compare the ratings on each rail, and compare the combined wattage ratings for 3.3+5.
      • yanz
        • Nov 2004
        • 910
        I'm afraid it will have the same failed fuhjyyu/jamicon caps. Better try another brand like mentioned above (300-400W PSU).
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
        • Byte_76
          Understanding capacitor ratings
          by Byte_76
          Hi, I have some capacitors that I need to replace on a graphics card.
          I've attached pictures for reference.
          Please help me to understand the ratings so that I can order the correct replacements:
          1. G7 560 2.5E - I believe these are for vcore
          • Is this 560uF and 2.5V?
          • What does the "E" mean?
          • Is there any relevance to the "G7"
          2. ECX 17 560 2.5V - I believe these are on the memory phase
          • Another 560uF at 2.5V?
          • This is on the same graphics card. If the caps are rated the same as those above, why are they a different type?
          05-10-2024, 07:56 AM
        • Lostdotfish
          KZG caps failed on a NOS motherboard - never been used...
          by Lostdotfish
          This is a new one on me. I picked up a new old stock DFI 865PE Infinity board recently. It's completely new, never used. While inspecting it I noticed some unexpected bulging caps...
          All of the 6.3v 1500uf caps had failed in place, despite the board never seeing use and being stored sensibly. I pulled the 16v caps that are the same series as a precaution and will replace them all.
          10-15-2025, 04:29 AM
        • modtool
          Lenovo Legion 5 15ARH05H, NM-D281 Rev 1.0, "BIInitializeLibrary failed 0xc0000185" and bios freezing
          by modtool
          Dear members,
          I have a problem with this machine that still I can't solve, I hope some of you can suggest me something.
          I was the first one to open the machine and touch the mainboard, in fact the Lenovo seal was intact the first time that I unscrewed all the internal screws.
          The ower told me that it was working very good until Windows kicked "something like a firmware update" (owner's words) then the system started acting weird.
          When you try to start it, some seconds after having pressed the power button, Lenovo splashscreen appears, then after 1 second, in the...
          01-15-2024, 08:56 PM
        • gurj1979
          Surface Laptop 1769 SSD Failed KUS040202M-B000
          by gurj1979
          Hey guys,
          I've got a Surface Laptop 1769 (the nasty cloth type palmrest) which has a failed 512GB Samsung PM971 (KUS040202M-B000).
          These are on BGA291, but I don't know which is equivalent to KUS040202M-B000.
          AliExpress has this but it's expensive.
          Can anyone help me find a reasonably prices equivalent which I can use as a replacement ?
          Or which NVMe can I remove it from ?
          02-17-2025, 04:02 PM
