Need schematic diagram of this Super-MITE 11, SM11-2/230A
  • maxbarjr
    • Mar 2016
    • 46
    • Philippines
    Anybody know where I can get a schematic diagram of this power supply? It is rated 12VDC@84A switching power supply. The unit is not working and have some dark marks on the pcb, a sign of overheating in that area.
    Thank you in advance.
  • CapLeaker
    Leaking Member
    • 8005
    Re: Need schematic diagram of this...
    Can you upload some high resolution pictures of the board(s)?
    • maxbarjr
      • Mar 2016
      • 46
      • Philippines
      Attached photos as requested. Although may not be a high resolution but that's the best I can get.
      • redwire
        • 3900
        It is a LH Research power supply, Super-MITE 11, SM11-2/230A
        All I could find is manual and schematic for SM10 https://archive.org/details/bitsaver...lJul79_2048801 which might be similar.
        Unitrode NTC3023 IC DIP-24 I've never seen before
        • maxbarjr
          • Mar 2016
          • 46
          • Philippines
          redwire, thank you for the link. I will have a look if any similarity.
          • birchy7
            Arcam FMJ A29 Stero Amp - schematic diagram of power supply
            by birchy7
            Hi, I'm hoping someone on here can supply or point me in the right direction for a service sheet for the above amp.
            Its on the bench, no power, all 3 fuses on main board are intact. no voltages are coming out of the mains tranformer, but it is recieving its input voltages ok, theres a relay in circuit with the transformer that might be my problem, either that or the transformer itself, would love to have the circuit diagram just to see how exactly this operates, many thanks in advance...cheers
            EDIT, sorry made a typo, its the ARCAM FMJ-A29 i need, not A32, sorry all
            09-25-2024, 10:59 AM
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • titimimo
            IB250CX schematic diagram
            by titimimo
            hello Guys Titi here ,
            hope you are ok,i am looking for help,any one with schematic of IB250CX schematic diagram( lenovo M710e)
            mine has an ic above sata has removed and i can't guess the number or if it was a regulator
            please if you know let me know the type of this chip
            computer work except to recognize hdd or ssd disk ,normally i can't install windows even if disk shows up or run windows
            thanks
            04-03-2025, 09:24 AM
          • Kirve
            I need schematic and diagram for Asus X556U Rev2.0 mb
            by Kirve
            "Hello friends. My Asus X556U laptop is not charging, not turning on, etc. I wanted to repair the motherboard, partly for learning purposes. One of the capacitors is giving a 24V output, and one of the MOSFET pins is also giving a 24V output, and honestly, this surprises me. I think I need to replace the capacitor, but I don’t know the capacitance value. I tried searching for a motherboard schematic but couldn’t find anything. Can you help me find the schematic or diagram?"
            12-18-2024, 11:09 AM
