24v charge controller help
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    this of coomber dance combo 2350 . which are a local company to me as it happens .
    have already been up there and used the facilities to swap the amp board so would rather not bother them with this .
    ok red fault lights lights constantly they are brand new batteries . charge light never lights . dual diode next to battery connector reads oddly on the board as reads in reverse on one side and other side because parallel resistor . v4 smd dual zener diode . looks like its been changed before .
    will get better pics .
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: 24v charge controller help
    more pics
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      talking to myself again as nobody joining in ..ordered 50 dual 3.6v zeners . in the hope it will fix the issue . they are only 1.2 pence each so can afford to drop a few on the floor .
      • redwire
        • 3910
        SOT23-6 switcher does all the work? It doesn't look like much of a power supply.
        All parts are tiny except for the big inductor and diode, and almost nothing for output capacitor 47uF.
        The SOT23-3 part is the one giving you trouble?, I would trace out the circuit a bit and it looks like it's for current-limiting the battery charger. The three R220 current-sense resistors eventually go to the base.
          • 31086
          i dont even know what this is - more background would help
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            the board basically tells state of charge .or rather it should do . red light should go out when charged enough but is staying on . the other lights should also light when charging but dont .
            one thing i cant figure out is why the charger is only at 24v open circuit when the batteries need 27.6v to charge properly .
            the red led is the one nearest the dc input socket .
              • 31086
              well it's several circuits then.
              a voltage sensor, and a charger.
              the sensor probably drops the charge from 27+ to 24 when the battery stops drawing current to keep it toped off.
              so first move is to give it a constant load like a lamp across the battery to force the charge to continue.
              then see what it does.
              • petehall347
                • Jan 2015
                • 4427
                • United Kingdom
                no the charger only supplies 24v . unless it rises with load .
                will see if i have a 24v lamp
                  • 31086
                  well if it supplies 24v then it wont charge a 24v battery.
                  • redwire
                    • 3910
                    From the big inductor and output diode, it's a boost converter configuration.
                    It looks like a microcontroller drives the LEDs and does charge control. Or it's a UCC battery charge controller.
                    I would get the part number of the SOT23-6 part and take some readings on its pins to see if it's held off or is dead.
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      sot23 6 . is a 562n .whatever that is ...4 pins connect together on the board .
                      8 pin device next it is s14b ..or 514b
                      other chip is MRC019 it 013 ,
                      they are hard to read even with magnification .
                      • redwire
                        • 3910
                        SOT23-6 mosfet FDC5612 N-ch 60V 4.3A
                        S14B is LM3478MM switching regulator
                        No hits on MRC, it might be a MCU. It's the top marking line that matters, EZD5?
                        Why a 4-pin battery connector, and that one soldered part looks like a train wreck.
                        I would trace out some of the circuit.
                        • petehall347
                          • Jan 2015
                          • 4427
                          • United Kingdom
                          4 pin connector as 2 12v batteries to make 24v .
                          EZDD by the looks of it
                          will get get those 3 voltages tomorrow for 6 pin fet
                          • petehall347
                            • Jan 2015
                            • 4427
                            • United Kingdom
                            just checked the v4 marking before replacing and noticed its a wv4 and not a zener ..
                            BAT54S .. it checks ok in circuit apart from the 100 ohm resistor across pins 1 and 3 making it not possible to check it .
                            will get those voltages soon .
                            • petehall347
                              • Jan 2015
                              • 4427
                              • United Kingdom
                              voltages at 6 pin fet
                              drain 23.9v
                              gate 0v
                              source 0v .
                              this is using - at dc socket as ground reference . 24v supply and batteries connected
                              • petehall347
                                • Jan 2015
                                • 4427
                                • United Kingdom
                                way i am seeing this is lm3478 is not working . all other pins appear to be fine and connecting to where they should .
                                • petehall347
                                  • Jan 2015
                                  • 4427
                                  • United Kingdom
                                  figured out the ezdd .. lm3478 .. op amp . its vcc is fed of the bav70 dual diode from the batteries . so looking like it has multiple problems .. i tried jumping the bav70 with a diode but no change with lights obviously as its not charging .
                                  • redwire
                                    • 3910
                                    It's a quad op-amp for the charge controller? What are the three LEDs and the 6-pin connector for. It looks like some signals come from the other board.
                                    The charger seems to monitor the battery pack center (12V node), and that is the portion somebody soldered up and mangled the transistor there. That might set the fault LED, if it can't see the pack midpoint voltage.
                                    • petehall347
                                      • Jan 2015
                                      • 4427
                                      • United Kingdom
                                      6 pin connector goes to amp board .
                                      i ordered a new pwm controller .
                                      yes it goes to centre voltage of batteries .
                                      looks like op amp is for led lights ..
                                      red is for battery fault ..
                                      other 2 are state of charge and charging lights
                                      one side of dual diode thats badly soldered goes to pin 11 of op amp . + input 4 .
                                      other side to ground
                                      • petehall347
                                        • Jan 2015
                                        • 4427
                                        • United Kingdom
                                        have had word this board is obsolete so i cant chance ruining it .
                                        dual diode replaced that powers op amp is now replaced and working .
                                        the other dual diode the zener one that goes to battery centre will be here soon . old one sort of tests working out of circuit . it makes me wonder if correct replacement was used last time .
                                        pwm controller is being slow to arrive . hoping i dont need it as no good way way of getting old one removed as yet . need the hot air .
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • master3112
                                          ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                                          by master3112
                                          I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                                          When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                                          10-29-2024, 09:32 PM
                                          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                          Narrow VDC applications where the system power source is
                                          either the battery pack or the regulated output of the charger.
                                          This makes the max voltage to the system equal to the max
                                          battery voltage instead of the max adapter voltage. Operating
                                          at lower system voltage can improve...
                                          11-05-2024, 04:43 PM
                                        • lethbrp
                                          OMRON E5CS heater controller Diode identification help
                                          by lethbrp
                                          I have a diode that I need help identifying. I've been scouring the web (newbie) can can't seem to find anything. Perhaps I'm looking in the wrong place. Attached is an image of the diode. If you could help me it would be greatly appreciated. Also, an explanation of how to calculate the values would be great.
                                          Thanks for your help.
                                          Peter...
                                          08-11-2023, 03:12 AM
