24v charge controller help
  • petehall347
    • Jan 2015
    • 4440
    Re: 24v charge controller help
    guess i need to draw a schematic to figure out the zener bit . saying that i am thinking cathode of one half goes to op amp . pin 4 + . not sure on other half yet .
    • petehall347
      • Jan 2015
      • 4440
      dont know why i said zener ..its not ..its bat54s . and new one didnt fix it ..pwm controller coming soon . so far as i can work out it should be driving that fet all resistors appear good . no shorted or open semiconductors . no shorted caps .
      • petehall347
        • Jan 2015
        • 4440
        new controller ic fitted ..still not charging ... aaaarrrgghh
        . am going to see if i can get voltages at controller pins .. am thinking it might be in protect . or i am missing something .
        • petehall347
          • Jan 2015
          • 4440
          pin 3 FB 782mv .
          pin 6 DR 0v
          • petehall347
            • Jan 2015
            • 4440
            pin 7 FA/SD 6.52v ..
            pin 7 has a 100k resistor to ground
            am wondering if the fet is ok .. its not shorted . but might be open .
            • petehall347
              • Jan 2015
              • 4440
              #26
              tried switching fet on with my meter and it stays off . its still in circuit though .
              • petehall347
                • Jan 2015
                • 4440
                #27
                after lots of studying i decided to test the inductor 22UH 1.6A SMD . my meter doesn't read it as a coil . on any setting . thought i would give the sniff test and it smells burned .. now to find one to use for testing .
                it is still in circuit . not sure if that would affect testing it at all .
                • petehall347
                  • Jan 2015
                  • 4440
                  #28
                  DOH silly me forgot how to use my meter .. its testing as .021mH
                  • petehall347
                    • Jan 2015
                    • 4440
                    #29
                    ok so i worked out the feedback for the controller goes to the other circuit with the op amp which is actually a comparator . it seems to end up at the charge light .
                    looks like the comparator might need changing next ..
                    although i dont understand these things very well but how will feedback happen properly until there is something to feedback ?
                    back to why the controller wont start . or why its shutting down and its faster than i can measure it . 30ns is pretty quick .
                    output 1 and 2 are shorted together .. they end up at that red battery fault light that fails to go off
                    • petehall347
                      • Jan 2015
                      • 4440
                      #30
                      just need to be sure what this ezdd device is to replace it . or first diagnose it properly .. without a schematic its not easy .. drawing it out is beyond me .
                      trying to work out out how its supposed to work and how its working now .. not knowing that part is holding me up now .
                      • petehall347
                        • Jan 2015
                        • 4440
                        #31
                        search says its lm324 .. input shorted to output if so ..
                        scratch that ..vcc is pin 3 .
                        • petehall347
                          • Jan 2015
                          • 4440
                          #32
                          ezdd 339
                          lm339 ..
                          • petehall347
                            • Jan 2015
                            • 4440
                            #33
                            ok 25 comparators ordered along with 5 fets .. min order .. good job they are cheap enough to buy .
                            if this dont fix it i wont have much of a clue what to do .
                            • redwire
                              • Dec 2010
                              • 3912
                              I'm taking a guess at how the charger works.
                              Normally, the LM3478 and mosfet boost the input to ~27.5V charging voltage for the battery pack.
                              If the battery mid-point voltage is out of spec, light the fault LED and shut off the boost converter by turning on its shutdown pin 7. If pin 7 is over 1.35V the converter goes to sleep. The pcb via goes to the comparator which can turn the converter off.
                              The three 0.22R set peak current to back off above 1A and seem to activate that mangled transistor if peak current is higher. That would maybe indicate bulk charging.
                              It (comparator) might also look for too low or too high a battery voltage.
                              It's hard to tell if it's mainly for the LED's or does a bunch of charge control too.
                              • petehall347
                                • Jan 2015
                                • 4440
                                #35
                                mangled transistor is a dual schottky . i replaced that for a new one .
                                • petehall347
                                  • Jan 2015
                                  • 4440
                                  #36
                                  this is turning out to be fun .. changed the comparator and constant blue light on batteries .. charger not connected .
                                  connected charger and red light on with blue .. disconnected charger then connected it again . this time the dual diode that supplies the comparator power decided to smoke .. just put in new dual diode .
                                  one thing i noticed this time is 4 input - is now 1.2 ohms to ground ..it was like this before i connected any power .. looks like the comparator needs another new one .
                                  i might even see if it charges or smokes with comparator removed .
                                  • petehall347
                                    • Jan 2015
                                    • 4440
                                    #37
                                    and we have a result .. another new comparator later .. battery only no lights .. charger connected and batteries blue light on .it went up to around 30v then dropped to around 27v . then tiny sparks at dual diode . then charging at 26v ..left it a few mins and went to 26.1 then 26.2 .. dual diode tests ok so maybe my soldering is bad there .. will touch it up tomorrow .its too late tonight to do it ..
                                    • redwire
                                      • Dec 2010
                                      • 3912
                                      Is the battery pack OK, the mid-point is ~12V?
                                      I would stop and trace out the circuit around this dual-diode to see why it keeps roasting.
                                      • petehall347
                                        • Jan 2015
                                        • 4440
                                        #39
                                        its not roasting now ..it tested fine after second new comparator fitted .. was arcing from my bad soldering .. well i hope its just that . still need to look at it some more ..
                                        • petehall347
                                          • Jan 2015
                                          • 4440
                                          #40
                                          job done and seeming to be working as intended ..voltage creeps up to 28.5v and charge light goes out .. left it with the owner and he is going to run batteries down and see if low voltage light comes on .
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • master3112
                                            ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                                            by master3112
                                            I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                                            When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                                            10-29-2024, 09:32 PM
                                            MPPT 60AMP Solar Charge Controller 12V 24V 36V 48V DC Battery Regulator Testing results on 12 volts
                                            I bought one recently but this is the first weekend that I did not have work Saturday morning or the sun did not want to cooperate with me but today it is coordinating with me and I run a very simple test on a 12 volt battery pack and it stop charging ar 14.4 volts
                                            Here is the website link where I bought it from
                                            https://www.ebay.com/itm/395434828814
                                            I ran this test with a new 12 volt solar panel that has a no load voltage of 19.0 and an output current of 9.1 amps
                                            I do not remember the starting voltage but the charging amps was 1.4 amps
                                            09-14-2025, 11:49 AM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
