Corsair HX650 no power (possible fix ?)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I've got a pretty tempting project on my hands here: someone gave me a Corsair HX650 semi-modular PSU to have a look and said I could keep it if I can't figure it out...how could I say no to that ? The game was on !
    So: the thing doesn't turn on despite 5vSB being present on the purple wire - one of the worst case scenarios and the most difficult situations to diagnose....
    Took the board out (which took way longer than necessary) and started measuring stuff...no shorts in any of the main semis, obviously, since the fuse is OK and has standby. No obvious signs of capacitor failure either.
    I slowly began tracking the problem down to the only major component that could pe causing this sort of behaviour: the UCC28515 IC located on a small riser in the very corner of the supply, tucked away behind the PFC coil....ok, now what ? I browser around a bit and found THIS where they actually managed to fix one. It's a different corsair PSU, but it's almost identical nonetheless. I'm hoping there are some native russian speakers around here who can translate that better than google can, but it was enough for me to sort-of get the gist. Apparently I was right on the UCC IC being the cause: it's not receiving VCC due to a small SMD transistor gone bad, apparently Q306 from what I can make out. I don't have the PSU in front of me right now, so I'm having a hard time following where this transistor is located, esp since they weren't clever enough to actually mention the damn part number :| I THINK it's near the pins where the daughter-board plugs into the main PCB.
    Will do some more testing tmmoz and post back. Just wanted to open the thread in case someone had a similar experience or at least one that comes close and can provide some feedback. Cheers....no need for pictures since the russian forum has all you may need
    Wattevah...
  • Stefan Payne
    • 1267
    Re: Corsair HX650 no power (possible fix ?)
    pls make pics of that unit and post it here.
    PS: I'm interested in the Supervisior IC, if it has LM339 or not.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      There are some pics on the forum I linked to. I'm guessing you're looking for a specific component. I shall post some pics later today hopefully.
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Did some more digging and even drew a partial schematic of the area that interests me (gotta love that dirty toilet paper I drew on )...I suspect Q310 not "opening" to let VCC get to the IC. 17v from the stand-by supply are present on the emitter of Q310, but I only get around 2.3v on the collector (output). Now I'm trying to find a replacement for it. What could t06 mean ? This website tells me that t06 is a PDTC124EU NPN...should I go with that ?
        I couldn't find a "W06" the russians were talking about.....
        Wattevah...
        • Stefan Payne
          • 1267
          Yes, I'm looking for the Area where the green and grey cable are soldered to front and back side.
          That should be the Protection IC.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            I made another discovery: apparently the W06 the guys were talking about is identical to my t06....a PDTC124EU also, so I think I'm on the right track. Still, I can't quite understand why they removed Q306 also (see it removed in one of the pictures there)...that's what threw me off a bit there....
            Wattevah...
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              Ok, while I'm waiting for the transistors to arrive, I'll tend to your request as well. Here's the part in question.
              Wattevah...
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Whenever I see an SMD transistor ending in "04", "05", or "06", I can't help but think of the 2N3904, 2N3905, and 2N3906 general purpose transistors (the 04 is NPN type, while the 05 and 06 versions are PNP). On that note, are you sure the "mystery" transistor in your schematic is not a PNP type? The way it's connected, it would make more sense if it is PNP. When the optocoupler is turned ON, it pulls the Base of the transistor low, and that allows the 17V Vcc supply to flow through the transistor to the PWM controller.
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  Yes, it would make a lot of sense for it to be a PNP, but the marking tells me otherwise. Could it be because the emitter is connected to volts and the collector is used as the output ? That way, the base would be of an opposite sign and "attract" the current....could be HORRIBLY wrong though, so I may have identified the part wrong....
                  Wattevah...
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Have a look here....there's capital letters as well as lowercase ones on those bastards...I'd say it's pretty clear the one I got is a lowercase T, which would make it a NPN, however its uppercase counterpart directly above it in the list is indeed a PNP, to further confuse things....did they really need both upper and lowercase characters to identify these parts ?! They're small enough as they are, so this adds another layer of frustration
                    Wattevah...
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      Very contradictory info here, since both the W06 and t(lowercase)06 are NPNs PDTC124EU, whereas the russians claim that W06 stands for PMBS3906 which is PNP which would make more sense. My board indeed has a t06 there, so who do I trust ? What's the worst thing that could happen ?
                      Wattevah...
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        Decided to go with the PMBS3906 PNP type, since my experience tells me a PNP should go there and it's probably O6 not zero-6, which WOULD make it a PMBS whatever....I sent my buddy off to get some from the local radioshack, but he came back with the wrong type.....I'm running out of time here, so I'll stick a TO-92 2N3906 in there to see if it at least fires up...
                        Wattevah...
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          Made a little bit more progress: I ran some wires from the TO-92 transistor to the respective pads to replace the SOT-23 one and it DID fire up.....for a second. Nothing went boom, but I DID see the voltage on the main cap rising to around 380v and the outputs went high then stopped....it could be because there's no load....haven't tried it yet...I doubt it though. Something's still cutting out...
                          Wattevah...
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            PSU is working now: the missing load was causing the issue. I put a 12v car headlight on the output and it remained on. Apparently the fan itself is that minimum load, since when I closed it back up, I removed the lamp and left the supply just on its own and it still worked. Anyway, case closed for now. Will keep you guys posted if it blows up overnight
                            Wattevah...
                            • shomi75
                              • Mar 2011
                              • 7
                              • Serbia
                              Thank you. It worked for me. I replaced it with bv4 (2SB624BV4)
                              • h0m3w0rk
                                Random Shutdowns/Startup Failure with Corsair SFX 450
                                by h0m3w0rk
                                I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                                For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                                02-09-2025, 03:19 AM
                              • coinwizx
                                Corsair HX1200 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
                                by coinwizx
                                The power supply is 2020 Corsair HX1200 modular power supply.
                                Cause of damage: I connected EVGA molex cable to the Sata port and test it with a ATX tester. Since the pin out on the EVGA is wrong, result in the 12V pin shorted to the 5V pin, in the 12V back-feeded to the 5v port.
                                Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then try to re power up....
                                09-15-2025, 12:46 PM
                              • zunasthegreat
                                Dead corsair VS450 with blown TNY chip (cwt)
                                by zunasthegreat
                                I have this Corsair VS450 PSU which lies dead and has an exploded TNY chip. Upon removing primary side parts like mosfets, the bulk cap and the bridge rectifier I've found that the primary cap is also a goner. (Photos)
                                The mosfets and the diode are fine and survived the collapse it seems. The TNY chip is shattered and from the online review/sources it was probably a TNY176~177....
                                08-30-2025, 03:11 AM
                              • hobostove
                                Corsair RM1000e - Help identify 5VSB Zener diode
                                by hobostove
                                Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                There's a 22ohm resistor that's melted and open, but it still has the bands.
                                The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                It looks like the diode connects the source and drain of a TNY284...
                                03-27-2025, 02:25 PM
                              • W1ngl3t
                                Corsair RM850x (synchronous ATX) need help troubleshooting
                                by W1ngl3t
                                I have a Corsair RM850x that refuses to turn on. I have 5v stby but as soon as I try to power it up it goes 'click' and does not deliver any voltages.
                                I have not been able to find any blown or shorted components and there are no bulging capacitors. I have replaced the APFC controller and for a brief period (2 or 3 on/off cycles) the PSU worked but then the fault returned. Perhaps heating the PFC area is what resulted in the temporary fix?
                                The only option I see now is to start pulling components one by one, but before I proceed, perhaps someone more knowledgeable...
                                03-15-2025, 04:43 PM
