Repairing Fortron Epsilon 600W
  • Brainless
    • Nov 2009
    • 8
    • Bulgaria
    I want to restore one old PSU. I found the main reason to not working. It was small cap (100uF/25V) on the Vdc bus going to the PWM controller. I replaced the cap with 470uF/25V (don't have currently 100uF) and PSU now works, tested under load with old GPU (ATi HD5830) and Furmark software. The replaced cap doesn't have any external signs of malfunction, even with capacitance meter is value is OK. But with it Vdc bus is ~11V and adding a small value like 4.7uF put the bus right, where it should be ~15.5V.
    What currently doesn't like is the spikes on 12V and 5V buses. Please see the attache files.
    What can be the reason for such spikes? Main big filter cap? It is CapXon 470uF/420V and its value is also OK.
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Re: Repairing Fortron Epsilon 600W
    i recommend u post photos of the inside of the psu and where that small cap is located inside the psu.
    we need to see if its a group regulated design. from the power label u posted, it looks like it could be. if so, if u use a 12v hungry cpu and gpu, the 12v rail will sag and the 5v and 3.3v rail will go high. u need to load all 3 rails at the same time to keep them within spec.
    were u able to scope/test the psu previously before that small cap failed? if it behaved the same way before the recap then its normal behaviour.
    otherwise, it could also be that the filtering caps for the 5v and 12v rail are starting to go bad. fsp luvs using teapos and capxons in their psus so considering the age of the psu, it could be that the secondary side filter caps are bad too.
    • Brainless
      • Nov 2009
      • 8
      • Bulgaria
      Thank you for the reply. The attached schematic is very similar to my PSU.
      The replaced cap was C15, which in my case was 100uF/25V.
      I found that for all caps, even they have the rated capacitance, their ESR is probably terrible due age. Just adding 100uF/400V to main filter cap, reduced the spikes more than twice. I ordered replacement for all caps.
      • Brainless
        • Nov 2009
        • 8
        • Bulgaria
        I replaced all caps, but the problem is still here - big spikes on all rails, with load and without. What is the usual voltage on the main filter cap? Currently is 400V.
          • 31051
          leave the 400v cap alone, it's not related to 200KHz spikes with what looks like some kind of resonant echo.
          check the output diodes and snubber parts.
          and what caps are you fitting??
          • jarvis7
            • Feb 2015
            • 52
            • asasf
            Hello ,
            I am guessing that these types of spikes are harmful/damaging for other PC hardware ?
            Assuming PSU is using good quality Low ESR caps
            is their any way of making sure that this does not happen without having oscilloscope or other expensive testers to test, simply with a basic multimeter ?
            I mean as a complete newbie i get the impression from reading posts here that , simply using good Japanese Low ESR caps should be enough for a decent power supply to supply clean and safe output and be completely reliable.. else if something else in PSU is bad it would supply really bad voltages or won't work at all , something easy to discern..
            this thread seems to suggest otherwise .. so if i buy a decently designed old used power supply and recap it with Japanese low ESR caps it still can be dangerous and unreliable and i cannot be fully sure that it is safe without having scope etc even though it is running PC fine ????
            sorry if questions are too basic..
            Thanks..
            • Stefan Payne
              • 1267
              No, you need to look at the voltage and for that you need an osciloscope.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                I don't know what gave you that idea.
                If anything without a scope it's much harder because you must match the capacitors to the original as close as possible.
                And sometimes finding trustworthy datasheets for these crap brands can be impossible, case in point:
                https://www.badcaps.net/forum/showth...013#post805013
                • jarvis7
                  • Feb 2015
                  • 52
                  • asasf
                  Thank you very much Stefan and Per Hansson Sir
                  • Satdude
                    FSP Epsilon 600W not turning on
                    by Satdude
                    Hi, I have a FSP Epsilon 600W computer PSU which had a bunch of bad caps, so I replaced them thinking they were the problem but the PSU still doesn't work. i don't have 5V standby and shorting the PS_ON to GND also doesn't turn it on. Fuse is ok and I get some inrush when plugging in. Does anyone know about any known faults in this series of PSUs?
                    07-18-2024, 11:11 AM
                  • petehall347
                    100nf and 100uf precision capacitors
                    by petehall347
                    i am wanting to calibrate my multimeters and for this i require a 100nf and 100uf precision capacitors . trouble is i can't find them ....
                    08-13-2024, 06:56 AM
                  • ten-d
                    Nippon Chemi-con 100uf 100v BP electrolytic cap
                    by ten-d
                    Hi all!
                    I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
                    01-30-2024, 05:18 PM
                  • jguy
                    etasis 600w 1u Psu or mobo?
                    by jguy
                    Hi guys, basically i fired up a server rack i had by my mum for the last 2.5yrs unplugged. It has a etasis 600w 1u psu and dell t1600 motherboard. It went through all sorts of random reboots and power cycling for about 2 minutes thought something was fried but suddenly it worked fine and has been even after unplugging for hours now, thoughts?
                    03-11-2023, 02:44 AM
                    Meanwell Switching power supplies intermittent every capacitor under 100uf
                    by sam_sam_sam
                    Here is the eBay website link where I bought them from
                    https://www.ebay.com/itm/276135936202
                    I have been waiting for these switching power supplies to come well they came in today so I took one apart and found that it Capcon and EIite and another brand that is on my list of capacitors to replace on site it has several 0.47uf @ 50 volts ESR value twice the reading of a new one 10 UF @ 50 volts almost twice the ESR value of a new one 47 UF @ 59 volts with double the ESR value 100 UF almost the same as a new one it got replaced for good measure Iit was a brand if I see them...
                    11-25-2023, 06:05 PM
