Component detection help
  • conan981
    • Aug 2011
    • 72
    • ITALY
    Hi to all, and sorry if i put my post here since i couldn't find any other place that could be better. i am sure that here someone can help me to recognize a component from a soldering station board i have.
    It is a protection component, in first pictures is marked with a red circle, and is put in parallel with a diode rectifier BYR29F-600 (Rectifier diode ultrafastge)
    Component is broken It is quite all burnt and i couldn't find nothing with that marking.
    Soldering station is working the same, but without protection so i prefer to wait..
    here are some photos ..
    thanks in advance for any help
    Sincerly
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Component detection help
    Please ignore i thought it read 1802 which is sometimes capacitor markings which would of possible made it a
    18 pf capacitor but not 100% sure
    • conan981
      • Aug 2011
      • 72
      • ITALY
      i supposed from his position it was some type of metal oxide varistor. (on the board near the other varistor is marked G1, and near my component is marked G2)
      the first line seems to be written 180Z
      if it was a capacitor shouldn't be written something else?
      btw thanks for you suggestion
        • 31250
        make & model of the equipment?
        maybe there is a schematic.
        that looks more like a MOV btw.
        • conan981
          • Aug 2011
          • 72
          • ITALY
          should be a Mov indeed.. but i would like to know the properties.. to buy something equivalent. Known that is used to protect diode rectifier BYR29F-600 there is no considerations we can do?
          SOldering station is old and couldn't find any schematic .. btw model is AC-DC 250 TIG
            • 31250
            what make?
            and the mov,
            maybe i'm reading it wrong, does it say:
            180z
            38i1
            and what is the diameter??
            • conan981
              • Aug 2011
              • 72
              • ITALY
              diameter is 7mm
              i read 180Z
              on second line 3811 (third char is 1 for sure)
                • 31250
                then i think it's a v180za1 or equiv
                • conan981
                  • Aug 2011
                  • 72
                  • ITALY
                  Great
                  Thanks mate, i'm going to try
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8703
                    I don't know why a MOV would be placed in parallel with a diode...
                    Is it really in parallel with the diode?
                      • 31250
                      or why it's rated at 115v running - i would expect that in u.s. or canadian stuff.
                        The cap is put in parallel with the Diode is for snubbing, looks to be 180pF and it should be rated at about 1KV. Most of the time they will put cap in series with the resistor to form RC snubber network and connected in parallel with the diode.
                        • conan981
                          • Aug 2011
                          • 72
                          • ITALY
                          So do you think it is not a varistor?
                            I cannot see why they will put MOV in parallel with diode.
                            Just think about it: If the MOV conducts when breakdown Voltage reached then the diode will be bypassed by the MOV which then the load will be fed with AC!
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              its odd i first thought it maybe be capacitor(post 2) but when you said the board id started with a G it made me question myself as all the capacitors i can see start with board id of C so yes does make you question things
                                I would like to see the straight shot pictures of the top and bottom side to verify the connection of that G2 device.
                                  • 31250
                                  G used to be used as a designation for spark-gaps in the past.
                                  • petehall347
                                    • Jan 2015
                                    • 4440
                                    • United Kingdom
                                    yep .have seen that recently in a philips tv .
                                    • conan981
                                      • Aug 2011
                                      • 72
                                      • ITALY
                                      Thanks to all
                                      Here are photos of front and bottom of pcb. if some other detail is needed let me know.
                                        • 31250
                                        it looks like one pin is connected to the diode, but the other looks isolated.
                                        check with a meter
                                        also
                                        the blue cap behind the diode is bad.
                                        is this a welder??
                                          HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-12-2024, 02:20 PM
                                          MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:20 AM
                                          HP EliteBook 840 G6 + UltraSlim Docking Station Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G6 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + UltraSlim Docking Station boardview and 840 G6 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 06:00 PM
                                          09-06-2024, 12:30 PM
                                          HP ProBook 640 G5 + UltraSlim Docking Station Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 640 G5 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + UltraSlim Docking Station boardview and 640 G5 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-06-2024, 10:56 AM
