Identifying a component
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    I need help to identify this burned Transistor from a Ryobi battery charger.
    Please check the photo, this is the best i can get for the ID.
    • 31248
    Re: Identifying a component
    lol - you need more than that.
    https://www.badcaps.net/forum/showthread.php?t=54038
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      Originally posted by stj
      Buddy, if i understand well, i need to replace all of these :
      "replace the fet with IRFR5505PBF
      replace the diode with BZT55C18
      replace the 2 diodes with a single MBR40250G on a customised heatsink with an insulating kit."
        • 31248
        probably,
        if the fet is bad, you should change the zener diode too.
        did you check the 2 mbr5200 diodes for shorts?
        • passete
          Living=Sharing
          • Jun 2015
          • 487
          • France
          probably,
          No I didn't, how do i check this, testing the 2 poles to ground ?
          Anyway, is better to change the 3 components ?
          Thanks buddy
            • 31248
            check the resistance between the 2 connections on each diode.
            remove them first.
