Emerson AA27020L Failures
  • mwarchut
    • Jan 2016
    • 8
    Hello
    I have 15 failed power supplies, all Emerson AA27020L units. At $400 a pop to replace they are starting to get a bit expensive. These all failed in the last 6 months so I am starting to think there is some common failure with them. Does anyone have any info on them and why they fail so I can take a shot at repairing them. I haven't seen much on the net about them but I suspect someone somewhere knows something about their secrets..
    TIA
    Mike
    • 31086
    Re: Emerson AA27020L Failures
    post foto's & stuff - upload them here, no linking to other sites!
    • mwarchut
      • Jan 2016
      • 8
      Sure thing.. I can take some thorough photos and upload them. I have good and bad psu's does it matter if I take a pic of a bad one or a good one? I opened a bad one and don't see any apparent issues visually.
        • 31086
        bad ones please
        • mwarchut
          • Jan 2016
          • 8
          Pics below of 4 different units.... Let me know if I missed anything.. Or if you need a 4K picture of one view.
          • cpt.charlie
            • Sep 2013
            • 270
            • Spain
            Do you have a proper voltage at the stand by rail (5Vsb)? what is the voltage at the main cap (the big cap at the primary)?
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              Adding a little to c.c's post above, it should be OK to power those on with no load. Look for the 12VSB pin and see if you have the standby voltage. That's a server PSU, of a type with a 12V standby voltage. I think the pin will be a single "finger", on the side opposite from the label. Also, look at the voltages on the other single pins, as you might see internal 5V or 3.3V housekeeping voltages. The chassis will be ground.
              Then, as c.c said, check the voltage across the big 450V rated electrolytic capacitor. If the PFC is working, the voltage should be around 400V. If the PFC is not working and your input voltage is 120VAC, then the voltage across that capacitor will be around 165V. Make this measurement carefully, as that is on the primary side. You do not want to short anything to the chassis, and you want to be careful for the sake of your safety.
              So, the first things all this checks are the Standby circuit and the PFC. If the PFC doesn't work, everything after it will be shut down. If the Standby circuit isn't operating, nothing will, as that provides the primary and secondary housekeeping voltages necessary to operate everything in the PSU.
              BTW, do pictures of just one PSU. Doing four at once just makes everything smaller, resolution for each PSU is worse, and the lighting is not optimized for any one PSU.
              PeteS in CA
              • mwarchut
                • Jan 2016
                • 8
                Sorry for the long delay. Personal issues got in the way of this project. So I finally got to look at these. The voltage at the big cap was 65V on both leads. I opened up a good PSU and found 65V on one lead and almost 0V on the other lead. Not quite sure what that means.
                When I plug in the good psu it makes a single click like a relay. The bad units do not. I will look at these a bit more closely today based on the additional data from PeteS as I had not seen the update until now. Thanks.
                • mwarchut
                  • Jan 2016
                  • 8
                  I found a bunch of marked pins that said 12v. They all came up almost 0. Anything else I should look for? Looking for any and all suggestions.
                  • mwarchut
                    • Jan 2016
                    • 8
                    So scratch everything previously posted. I found out that the old meter I bought like 15 years ago had finally given up the ghost. I went out and bought a new fluke. And now I have more accurate measurements.
                    Across the biggest cap the voltage is 160.1 On a good psu it's coming up as 392.6.
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      OK, your PFC is not working. Now try what I suggested above:
                      If you don't have 12VSB, your problem is probably in that regulator circuit (it also supplies internal housekeeping voltages, without which the PFC cannot work). If you have 12VSB but no internal housekeeping voltages, something is wrong on a control board, and that is keeping the PFC shut down. If you have 12VSB and the logic level housekeeping voltages, the problem is in the PFC circuit.
                      PeteS in CA
                      • Sus256
                        HISENSE 65E7KQ PRO - no boot
                        by Sus256
                        Hi all!
                        HISENSE 65E7KQ PRO
                        RSAG7.820.13512 - chassis
                        MT9618BAATAB - cpu
                        RSAG7.820.12059 - power
                        HD650Y3U77 - panel
                        KLM8G1GETF - emmc
                        The TV does not turn on, the standby indicator is on. All voltages are present.
                        Emms is dead. Not readable, not detected.
                        Replaced emmc.
                        But with another dump there is no launch
                        Terminal log
                        UART
                        AC_ON
                        RPMB key is not yet programmed
                        HASH1_VERSION=0x00000000 64bit
                        E-B
                        FDE enabled
                        layout pattern onebin by SAR7,0...
                        06-01-2025, 02:11 AM
                      • C152Heavy
                        by C152Heavy
                        Summary for TL-DR readers:
                        • VCC pin (18) of PFC...
                        01-11-2023, 02:53 PM
                      • modtool
                        Lenovo Legion 5 15ARH05H, NM-D281 Rev 1.0, "BIInitializeLibrary failed 0xc0000185" and bios freezing
                        by modtool
                        Dear members,
                        I have a problem with this machine that still I can't solve, I hope some of you can suggest me something.
                        I was the first one to open the machine and touch the mainboard, in fact the Lenovo seal was intact the first time that I unscrewed all the internal screws.
                        The ower told me that it was working very good until Windows kicked "something like a firmware update" (owner's words) then the system started acting weird.
                        When you try to start it, some seconds after having pressed the power button, Lenovo splashscreen appears, then after 1 second, in the...
                        01-15-2024, 08:56 PM
                      • jake-b
                        dell e6540 boots to black screen (no dell logo)
                        by jake-b
                        good morning all,
                        i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                        01-08-2024, 10:29 AM
                      • dragometin
                        Hitachi 40HYC42
                        by dragometin
                        TV Model: Hitachi 40HYC42
                        Power Supply: 17IPS71
                        MainBoard: 17MB95M
                        Panel: VES400UNDS-2D-NO3
                        When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                        I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                        Is there any variants on 17IPS71 power supply's?
                        UART output pins 10 and 12 on scart connector:
                        Code:
                        12:24:04.595
                        08-08-2024, 05:53 AM
