Mitsubishi Melservo MR-J2S-100A alarm: AL.E9
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Mitsubishi Melservo MR-J2S-100A alarm: AL.E9
    Hi, the ones I've seen have shown AL.E9 as first & only error AFAIK.
    I work as a service technician, so I get called whenever the customers can't get the machines working again...
    So far I've repaired quite a few of these and had 100% success so far, and no returns...
    Actually I'm near Tampere sometimes for customers too (actually in Lempäälä) but not right now.
      • Jul 2011
      • 6041
      Thank you for this posting I also repair servo drives I have had switching power supply problems from bad capacitor to bad switching regulator IC chips but have not yet seen this problem
      Thanks again for sharing this post
      • Leopard
        • Mar 2008
        • 109
        • Finland
        Thanks for the response. Nice to hear that the failure mode has been consistent.
        We've luckily had spare units for the ones that have been acting up, but apparently this model is outdated and hard to get nowadays.
        I'll order some optocouplers and will see if these can be brought back to life.
          • Jul 2011
          • 6041
          When I have done these drive before I have given them a recap and change the switching regulator ic chip and now when I do another one of these drive I will change the optic sensor and the surface mount capacitor as well
          After reading your post
          • Alex-Signals
            • Sep 2019
            • México
            hi, I made the change of the caps, and the HCPL7800A, in the DC BUS marks me an output of 280 vcd, the equipment was already installed in the machine and I am still working.
            Since I don't have 33uf caps, install some 47uf caps. they believe that for this reason I am giving a bus voltage of 280 vcd, the caps I use are low ESR
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              #26
              The bus voltage depends on the incoming AC voltage.
              If you measure 200VAC input then 280VDC bus voltage is normal.
              Calculation: √2 x 200VAC = 282.8VDC.
              If not and you believe you have a heat sensitive component then heat it up with a heatgun carefully and see if the voltage changes.
              Or cool it down and see if the voltage changes.
              This is the way I used to pinpoint that it was component O15 the HCPL-7800 that was the culprit as described here.
              And yes, the servo might be sensitive to the value of the capacitor, especially capacitor C6.
              • jae2020
                • Jan 2020
                • Philipppines
                #27
                Hi, these two caps came from a unit that otherwise is full of Nichicon caps:
                Nichicon GQ, GU & PJ manufactured late 2001.
                Got any idea what model they are? (See picture).
                The 33uF cap has an ESR of 40 so it's in dire need of replacement
                I could get it down to ca 5 by heating it with my iron, then matching the other cap...
                I ordered the "A" version of the 7800 optocoupler linked above from Mouser, actually it was the only one in stock.
                It worked a treat, the bus voltage reading is now correct
                Thanks. I solved alarm E9 after replacing this IC.
                • fazal kareem
                  • May 2019
                  • Pakistan
                  #28
                  IF Driver Shows
                  AL.E9 change ic chip 7800 80% solved
                  AL.24 change module 50% solved
                  but
                  AL.30 ?
                  AL.17 ?
                  • bench22
                    • Oct 2020
                    #29
                    Thanks! also fixed my servo with alarm 9.
                    • macona
                      • Oct 2020
                      I also had this same issue with my MR-J2S-100A on my cnc mill Y axis. Replaced that opto today and she is alive again. Thanks for posting all this!
                      • macona
                        • Oct 2020
                        Oh, and I thought I should add it does seem temp related, it was not until the shop got cold that this issue cropped up.
                          • Jul 2011
                          • 6041
                          ( these Servo drives are a pain in the ass to repair )
                          I have tried in the past to repair Servo drives that have a low buss voltage with limited success on some models it just replace all of the small value capacitor and that seems to fix the issue but not always the case
                          I have even replaced an IGBT module on one and never figured out what the problem was
                          With over current error message I have been more successful repairing this kind of fault
                          I have even repaired Servo drives that have priority controller boards this is even more channeling because if the controller board has issues it basically unrepairable but ( if the controller board still working) if you can find the same exact model then use the replacement drive with the original controller board and this dose work I have done this a few times before
                            • Jul 2011
                            • 6041
                            If this is a drive that is over 10 years old I would highly recommend that you recap the switching power supply board at a minimum and also recommend that any capacitor under 100uf replace them
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              #34
                              Nice to see so many new members in this thread, welcome to Badcaps!
                              On that theme I present you the latest repair:
                              I was hoping for it to be an "easy" fix but for the first time was greeted with leaking SMD capacitors in this servo!
                              The electrolyte had started attacking the through hole vias and crystalline formations had formed on the negative legs.
                              I used acetic acid and it worked a treat, I did not photograph the acids process in the first two caps but after what I saw was ready on the next couple.
                              I made this little GIF showing the action, the board turned out great after the cleanup thankfully!
                              P.S: I attached several high resolution photos of the before/after process as well, oh, and the SMD caps measured around 80 to 140 in ESR!
                              • ChaosLegionnaire
                                HC Overclocker
                                • Jul 2012
                                • 3264
                                • Singapore
                                #35
                                nice... u used acetic acid? isnt that whats in vinegar?
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  #36
                                  Exactly correct!
                                  I even bought it at the local food market
                                  • mohamed_bayoudh
                                    • Dec 2020
                                    • tunisie
                                    #37
                                    Hello
                                    I have an MR-J2S-60A
                                    I wired it by manual on 230v single phase,
                                    it lights up fine, but it gives the error
                                    Al E9 - "Main circuit de-energized warning"
                                    I don't know where the alarm came from.
                                    thanks in advance for all your help.
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      #38
                                      Hello, please write in English as this is a English forum, SMDFlea translated the post for you this time.
                                      You would begin by measuring the bus voltage on the main capacitors of the drive.
                                      And then compare this to what the drive shows the bus voltage as itself via its internal status display "Pn"
                                      • CBoulic
                                        • Feb 2021
                                        • france
                                        #39
                                        hi all, i'm new on this forum , and i happy to read this post because I have the same issue with a Servo Amp mitsubishi MR-J2S-500B. i'm sorry for my bad english, please don't be angry!
                                        I have 2 servo whit the same E9 one of two go to the repair society but they are not sure troublesoot it .
                                        so i want try troubleshoot the second by my self!
                                        m'y servo amp , show me an E9 and in the the datta sheet is :
                                        AL.E9
                                        Main circuit off warning Servo-on (SON) was switched on with main circuit power off.
                                        Switch on main circuit power.
                                        but this servo ( an 3 phases input) is powered . it smell the same error like you on your mr-j2S-100
                                        on your precedent mesage you say read the bus voltage I suppose you talk about the DC rail after the PD3( 3 phases Graetz bridge).?
                                        on this version of SAMP i' d'ont have button to enter the menu. and i d'ont have pilot systéme so is hard to make measurment.
                                        with your experience, i found one opto 7800 but is not near the DC rail is on the smalest PCB but i can change it !
                                        near the DC rail i found 0I12 , is an opto TLP621 and it's Diode is concted thougth the resistor to the DC rail i suspect a probleme with it.
                                        on my PCB OI15 is not a 7800 is V454.
                                        if your have idea i'm very interested about it!
                                        thank you so much
                                        • Per Hansson
                                          • Jul 2005
                                          • 5895
                                          • Sweden
                                          #40
                                          Welcome to Badcaps!
                                          Your servo also has the LCD display, it is just in another location.
                                          I attached photos of a 200A servo here, you can see the display behind the cover shows 322v.
                                          This DC voltage you can measure between terminals P & N that I labeled in the photo, it should be similar in your servo.
                                          (It is only the small servos (80A and below) that do not have one of these two terminals).
                                          But in any case you can use cooling spray: so cool down the opto you suspect and watch the "Pn" voltage in the LCD display:
                                          If you find the right optocoupler it will drop allot!
                                          P.S: I attached the display flowchart!
                                          Last edited by Per Hansson; 02-18-2021, 10:47 AM. Reason: Attached photo display flowchart
                                          • DrewPhillips
                                            Capacitor Diarrhea - Nichicon PL Series
                                            by DrewPhillips
                                            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                            03-02-2025, 10:18 PM
                                          • Tom41
                                            Honeywell Accenta G3 tamper alarm
                                            by Tom41
                                            This house has a Honeywell Accenta G3 alarm system. If the main unit loses power for any reason, the external siren sounds - even if the alarm is not even armed! Entering the code to disarm it is not an option as the keypads are completely dead when the power is out.
                                            I presume this means the backup battery inside the box has failed, but I can't get in there and replace it without also setting off a tamper alarm! Is there any way to disable the tamper alarm so that electrical work can be carried out with the power off? Or a way to replace the backup battery without setting off the...
                                            08-31-2023, 04:00 AM
                                          • nick3092
                                            Mid/late 80's Nichicon Yellow Caps
                                            by nick3092
                                            I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                            08-28-2022, 03:56 PM
                                          • slybunda
                                            Alarm Siren issue
                                            by slybunda
                                            Apologies if this is in the wrong section but being a car alarm siren that makes noise i thought it be best to put it in the audio section.
                                            Had weird alarm issues where siren made a strange noise: https://www.youtube.com/watch?v=ZjsqndhionU
                                            took siren out of the car and checked it out and pics attached seem to be the source of the issue.
                                            shockingly the alarm still makes its normal sound if i trigger it manually so speaker seems to be intact.
                                            getting a replacement is gonna be next to impossible, its a Toad Ai606 which is no longer in production and cant see to find a replacement...
                                            02-04-2024, 11:01 AM
                                          • Ady2017
                                            Does anyone know about 16x2 LCD screens used in alarm keypads?
                                            by Ady2017
                                            I have got an old Gardtec GT595 alarm which has got a faulty keypad with a failed LCD screen. This was apparently a very common problem with these and many people have had to replace the whole alarm because of this problem. Somebody claims to be able to repair the keypads by replacing the screen and I have tried it myself by replacing the LCD with a commonly available HD44780 1602 16x2 Serial LCD screen but it is not working. I am sure it is a problem with a driver or simular which is not allowing the screen to talk to the rest of the electronics. Does anyone know what this original screen was...
                                            06-02-2025, 04:56 PM
