Rectifier Datasheet
  • maxbarjr
    • Mar 2016
    • 46
    • Philippines
    Rectifier Datasheet
    I have 4 rectifiers that I can't find any datasheet for it. I believe these are power rectifiers. It is marked TR 50 (then the sign of a diode then looks like a T then) 702. Please see attached pix.
    Can anyone identify these and provide a link to where I can download the datasheet?
    Many thanks.
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Rectifier Datasheet
    Many thanks.
    What i can help with is the package type of these diodes . It is D0-4 package and sometimes they are designated as D0-203AA packaging . Try searching while including D0-4 in your query .
    • Khron
      • Sep 2006
      • 1350
      • Finland
      That's actual "DO", O as in the letter, not "D-zero"
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Both are correct and commonly used ..
        https://www.google.com/search?q=d0-4...w=1440&bih=789
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          I think those might be the next size larger package, DO-5. The logo looks like it might be Teccor, but it isn't clear in the picture, and I don't know if Teccor made anything in a DO-4 or DO-5 package. I know TRW did, back in the 70s and 80s, but they put "TRW" on their stud mount parts.
          PeteS in CA
          • srhofmann
            • Aug 2016
            • 135
            • usa
            I agree with PeteS they look like they are DO-5. DO-4 was removed from the JEDEC standard probably 20 years ago.
            maxbarjr - measure across the flats of the device - 17 mm or so is a DO-5 package. If I had to hazard a guess I would probably rate them around 50 amp based on the t50 marking and the package size. The T702 marking could be peak surge current, peak reverse voltage, peak reverse recovery current or a manufacturer part number.
            jiroy - D"zero" is incorrect and shouldn't be used. DO is correct - the O stands for outline. Take a look at the JEDEC standard JEP95
            • maxbarjr
              • Mar 2016
              • 46
              • Philippines
              Yes it is a DO-5 package. I measured it as 17.4mm. I also attach another pix showing the symbol like letter T before 702.
              Thank you.
              • srhofmann
                • Aug 2016
                • 135
                • usa
                I'm gonna stick with my original guess probably rated around 50 amps. After that it's a complete crapshoot. I think PeteS is correct in that it looks like a Teccor symbol, the greek letter tau, but I'm not that familiar with their products. I don't think I've ever done a design with any of their stuff and if I remember they mostly did three terminal devices likes SCRs and Triacs.
                • howardc64
                  QN75QN85BAFXZA no backlight
                  by howardc64
                  2+ year old TV with many (720? 65" version has 720) mini LED dimming zones. TV boots, has sound, panel picture can be seen with flashlight. No backlight. No TV model sticker on rear panel (Maybe Samsung service removed it, read below). Found the model # through the PSU and zoned LED driver board numbers.
                  PSU has a click near LED output circuit at 1 second interval, sounded like the 4x barrier rectifier area. Protective pastic liner under PSU shows heat signature on the Schottky Barrier Rectifier in this circuit. Found a shorted diode (2 diode per rectifier, failed rectifier labled...
                  07-03-2025, 05:08 PM
                • Steph.hen
                  Bridge rectifier identification part number KPB305G
                  by Steph.hen
                  Hi all, a newby question about a bridge rectifier I'm trying to identify.
                  I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                  08-29-2024, 09:52 AM
                • electomech-fixer
                  First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                  by electomech-fixer
                  I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                  I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                  09-15-2025, 01:42 AM
                  Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                  by momaka
                  This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                  Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                  Macron Power Technology Co. LTD.
                  Let’s look at the PSU itself.
                  The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                  06-02-2021, 10:05 PM
                • SoulFreeze
                  Help finding datasheet for component marked G34662
                  by SoulFreeze
                  Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
                  Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
                  Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
                  05-01-2025, 03:56 AM
