broken power supply Eaglerise SDT160FMS
  • serak
    • May 2013
    • 7
    • Czech
    Could anyone help me with the repair of this power supply for halogen lamps, please?
    It is Eaglerise SDT160FMS. Unfortunately I have not found a diagram.
    The first part includes a touch control dimmer NB7232, which controls (via triac and Photocoupler C1010) the second part, switching power supply with switching transistors KSH13009. No part visually looks like burnt.
    Unfortunately, I have only a digital multimeter Mastech MY64.
    I have partially tested NB7232. At pin 1 is DC 5V. Also at pin 8 (TRIG) is 5V DC. Because MY64 can also measure the frequency, I have tried to measure the frequency at the TRIG. There was 100Hz. Unfortunately, I do not know how to measure duty cycle. Although I have a simple oscilloscope 2MHz, I do not have isolation transformer and experience, so I'm afraid to use it in such type of circuit.
    I also tested all the diodes (without desoldering) and they seem to be OK. I also desoldered both switching transistors and measured hFE. The measured value was 30, so they could possibly be ok.What next?
    I appreciate any help.
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: broken power supply Eaglerise SDT160FMS
    Maybe this can help ..
    • serak
      • May 2013
      • 7
      • Czech
      Thank you. This datasheet i have found. On the basis of this datasheet (and datasheet of LS7232, which is older 15V equivalent), I actually made above mentioned voltage and frequency measurements.
        by sam_sam_sam
        03-31-2024, 02:12 PM
        by sam_sam_sam
        07-01-2024, 06:34 AM
        by sam_sam_sam
        After all of...
        07-13-2024, 08:14 PM
        DVR camera recorder switching power supply capacitor failure really
        by sam_sam_sam
        These cheap non brand capacitors at it again
        Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
        Well at least I have the cameras back on line I to try the...
        01-22-2022, 06:28 PM
