SMPS Motorola GPN 6133A / Magnetek 3812 19-1
  • johnwm
    • Oct 2014
    Hi ,I have several of these power supplies with various fault symptoms .Has anyone ever dealt with these before?. I think they where made for Motorola by Magnetek to supply desk top radio base stations.
    I`ve searched in vain to find any drawings or data on them, has anyone have a circuit diagram for it?
    Regards Johnm
    • Jul 2011
    • 6069
    Re: SMPS Motorola GPN 6133A / Magnetek 3812 19-1
    Take some pictures of both sides of the board and post them and let see what you have
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8339
      Also specify what exactly each PSU does and doesn't do. The only thing I know there might be a problem is with those Motorola part numbers. They have their own part numbering system.
      • dkneyle
        Onkyo DX-V500 Laser Disc Player - weird SMPS fault
        by dkneyle
        This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
        Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
        02-01-2022, 02:08 AM
      • shamsudeen
        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
        by shamsudeen
        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
        i know that in linear power supply the noise will be very low comparing to SMPS supply....
        07-19-2025, 07:14 AM
      • CapLeaker
        Motorola 22F43 14pin dip identify me
        by CapLeaker
        Got an old Motorola page out controller here. Something honking old. Came in as no workie. Without schematic or anything. So I did some probing around and found two 14 pin DIP IC's that I need an replacement for.
        Motorola 22F43
        Motorola 22F44
        Got no idea what these are.I got semi lucky and found a 22F44 on a donor. Unfortunately the 22F43 is already missing. If anybody knows what these are and find a cross would be greatly appreciated!
        01-21-2024, 09:12 AM
      • abhishekkumar1902
        Huntkey HK340-72FP SMPS shut on load above 2 amps
        by abhishekkumar1902
        I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
        I have checked the following:
        1. All output caps are OK, and all output rails read correct voltages at no load
        2. All output diodes are OK
        3. NTC is ok
        4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
        5. No short in main switching MOSFET
        6. All other components...
        12-18-2022, 09:52 AM
      • madan1
        Mackie Th15 SMPS low Vout
        by madan1
        I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
        It is basically a smps with amp and some dsp.
        The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
        Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
        By the way, the ferrite core of L10 is broken,...
        02-16-2025, 04:15 PM
