Got a "bad" HiPro HP-P3527F3 from a computer shop. On power up the 5vsb, 12 volts, 5 volts, and 3.3 volts all looked good. Power good working OK. But my power supply tester (bought on Ebay) beeped and for -12 volts indicated LL (low voltage).
So I pulled the power supply apart. No bulging capacitors, no burned areas or heat damage. So I began tracing the -12 volt circuit. Output filter caps were OK, then a turn or two on the group regulation coil, then a diode from source to ground. But the diode to the main switching transformer was never installed. Also, there was NO WINDING connected to the transformer pin which went to the missing diode. What???? So where does the -12 volt line get its power?
Take a good look at the schematic of the -12 volt circuit. The ONLY source of energy coming to this circuit is from the group regulation coil. Now it makes sense. The more load you put on the power supply 12 volt and 5 volt circuits, the more voltage that will be induced and transferred to the -12 volt circuit. That means that the -12 volt output will be low unless you load the power supply properly.
Looks like this power supply fooled a computer repair tech who most likely tested the psu with a cheap tester, saw that the -12 volts was low, pulled the psu as bad and replaced it with a "bargain basement 500 watt psu" that could do the job. Customer was probably happy to get computer repaired along with a more powerful psu!
) to completely miss and disregard the limitations of said "tester"- for one thing, those don't even load the device under test!
of course, where would the fun be in that?
