What do you think will it do 350 watts
Sparkle Power Supply SP1350PFB Good-Bad
3Yes0%2No0%0Maybe0%1Maybe not0%0The poll is expired.
Tags: None -
Re: Sparkle Power Supply SP1350PFB Good-Bad
Here are more photo
I bought these new - old stock surplus so who knows how long they been sitting around on a shelf
I paid $12.00 plus $9.00 shipping each
I bought two of them this one has not been recap yet the other one has been recap with
KY , KZE , LYX this power supply seems to work ok with these capsAttached Filesif you find these attachements useful please consider making a small donation to the site
Yeah, it is FSP, something like those HHN thingys, something like FSP Epsilon.
Not the greatest thing, but for a 350 more than enough, but rather +5V havy, sadly...Comment
Sparkle Power Supply SP1350PFB I want to modify this power supply
I would like to modify this power supply to put out 18 to 24 volts could this be done and what would I need to do and how
I would not need the 3 volts but would need the 5 volts + and -Last edited by sam_sam_sam; 01-28-2017, 07:01 PM.Comment
Re: Sparkle Power Supply SP1350PFB I want to modify this power supply
you need to change the design a bit ... choose where to take the 18 or 24v from and regulate it .. look at data sheets for intended regulators first .. then work out the current etc ...
why bother ? just buy ready made what you need .Comment
Because I have a few these power supplies and I did not pay much for them and I am looking for a challenge and some thing to work on
I also want to learn something as wellComment
Sparkle, despite a name that sounds odd to speakers of English (very close to "Spark", not a good association, IYKWIM), is solid. I'd like the heatsink to be a little more substantial, but with really good airflow it could be alright. One of them has caps that have puked their guts; at 6+ years old, that's not horrific.
Trying to change it to an 18V or 24V P/S could be challenging. The +5V winding turns ratio won't allow for that. And I would not be confident that the +12V winding (probably a winding "stacked" on top of the +5V winding, to take advantage of the +5V regulation) has that much capability. IF the +12V winding is capable, the duty cycle will be much greater, making your minimum AC voltage higher. If the output caps are 16V, you'd have to change them to 25V or 35V parts. Similarly, IF the +12V winding might be capable you would have to find the feedback divider resistors and change the ratio, specifically the "upper" resistor. If you can find it, I'd suggest starting with a potentiometer of 5X-10X the resistance you're replacing, adjust to the voltage you want, measure the resistance of the pot, and install the standard value resistor that is closest to that value (or just keep the pot).
I don't even want to think what would happen to the loop compensation or how to adapt it (maybe if there's a cap across the resistor you changed, find a value that keeps the RC time constant the same?)!
You might be able to pull it all off, but I wouldn't bet on it. But it sounds like you're doing this for fun and learning, so have fun. You definitely will learn.PeteS in CA
****************************Comment
Update—> I know that this is a very old post but it is the switching power supply's that I have quite a few of them
Like I said earlier in this post I bought even more of them because they kept having sales on them
I probably have about ten of them and some of them are 300 watt ones
and so far everyone have blowed caps on the output power rails and as far as I can tell these power supply were new never used because they are very clean inside of them
The biggest problem with changing the caps on this board is some of traces are very narrow and lift off the
board and there are two caps next to each other one in particular the one near the primary side of the board it a small UF value
The other problem with this board is that the output caps and the wires and inductor are all packed together in a small area which replacing is a pain in the a** to do
I have recapped another one of them yesterday and ran it all night and seems to run all rightLast edited by sam_sam_sam; 12-18-2020, 06:23 AM.Comment
Assuming...7 Photos -
by sam_sam_samI have bought computer switching power supplies from Electronic Goldmine before and every one of them the capacitors were bloated and or leaking out of the capacitors so I am sure that these are going to be the same way five or six years ago I had bought some 300 and 350 watt computer switching power supply from Electronic Goldmine these are all from FSP brand
Here is the listing for this switching power supply they only had three of them in stock and I bought all three of them
https://theelectronicgoldmine.com/products/g28149
I have one old computer that... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by sam_sam_samI have a 24 volt version of the same type of switching power supply but that one I am relocating to meter module and I might do the same thing with this one but I have to modify an enclosure that is not made for this type of switching power supply in fact I am not sure exactly what type of switching power supply it actually fits because none of one's that I have the screws holes do not line up and not even close but the switching power supply fits in the enclosure
So I have take out the switching power supply board out of its enclosure and drill the hole so that it can be mounted... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
- Loading...
