Replacing 2003 with 2005 ?
  • bianchi77
    • Jun 2016
    • 1121
    Everyone,
    Can I replace 2003 chip with 2005 on ATX smps ?
    I tried to find 2003, can not find it...
    Cheers
  • LA1
    Trying to find a datasheet for 2 smd's and the schematic for SMPS made by APEVIA
    by LA1
    I am trying to find two smd datasheets for an Apevia 1000w prestige power supply ATX-PR1000W the SMD's are ST9S313 which is a SMPS supervisory chip and a EST 915HP or XP48024 not sure which or both is the chp prod number and the schematic
    01-23-2024, 11:27 AM
    by Vesko356
    08-11-2023, 03:27 AM
  • danielgerman681
    ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
    by danielgerman681
    Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
    08-27-2025, 01:17 PM
  • dkneyle
    Onkyo DX-V500 Laser Disc Player - weird SMPS fault
    by dkneyle
    This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
    Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
    02-01-2022, 02:08 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
