question about "voltage divider?"
  • tablet3rs
    • Aug 2013
    • 57
    • philippines
    i was looking for this specific parts, its not available...
    BA33C18FP-E2-ND - Linear Voltage Regulator IC Positive Fixed 2 Output 3.3V, 1.8V 1A TO-252-5
    i have a question about voltage divider?
    i need 2 output in 1 input, 1.8v and 3.3v, i will used 5v input,
    [IMG][/IMG]
    will it work or not?
    will it be safe to use?
    thanks in advance...
    any comment will be much appreciated....
    • 31246
    Re: question about "voltage divider?"
    no, a voltage divider is current dependant.
    use a pair of 1117's if you have to.
    • tablet3rs
      • Aug 2013
      • 57
      • philippines
      thank you sir... appreciated
      • Fernon@Repair
        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
        by Fernon@Repair
        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
        VCCIO voltage ok
        VCCSA Voltage OK
        VCCPLL Voltage OK
        Ram Voltage ok
        RamVTT OK
        VPP 2.5 OK
        But No Core Voltage
        and i want to this vrm ic datasheet or pinout (ISL69269)
        anyone have this ic pinout voltages?...
        06-25-2025, 07:19 AM
      • electron_jj
        Panasonic TH-L42D25A checking the PSU output voltage
        by electron_jj
        Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
        I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
        08-29-2021, 08:13 AM
        Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
        by sam_sam_sam
        I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
        The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
        Now...
        06-09-2024, 10:57 AM
        ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
        3+1 Voltage Regulator for IMVP-7/VR12 CPUs
        Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
        core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
        configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
        serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
        Based on Intersil's Robust Ripple Regulator...
        11-05-2024, 03:24 PM
      • kwyjibo
        Help understanding ACDET voltage divider A315-23
        by kwyjibo
        Greetings.
        Aspire A315-23 board (da0z8emb8c0 Rev c), no power.
        19VDC is at PQ3 pin 5. Nothing coming out, and started working around the power circuit.
        The ADP_ID pin (3) was pushed all the way inside the DJ jack (new one on order), causing it to not make contact with the barrel connector on the AC Adapter (nothing new), and where it wasn't my laptop I didn't just want to jump it to the DC Jack ground and call it a day.
        I can see the voltage divider circuit from PR71 and PR69 to PQ9. But some reason I cannot remember how if the DC...
        01-24-2023, 11:02 PM
