Soundcraft DCP100 PSU
  • Johnwx
    • Jul 2016
    • US
    I have a very old Soundcraft DCP100 PSU and suddenly it doesn't work, do you guys have user guide (user guides from Soundcraft contain schematics of their products) of it? I wanna repair it. Thx.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Soundcraft DCP100 PSU
    Post some nice straight shot, high resolution pictures, so we can see something. Also describe exactly what is or is not happening, like blowing fuses, no output, wrong output etc. Some voltage rails working, others not, etc.
    By looking at the PSU there should be 3 voltage rails. +15V, -15V and 48V phantom power.
    I found a schematic for the Soundcraft 200b. That should give you a guide line on what to expect. It won't be the same, but it should be similar.
    http://www.mynetimages.com/a12355c6.gif
    • zx8401
      Phantom Fiddler
      • Aug 2013
      • 49
      • uk
      As its a conventional linear supply with mains transformer, i would connect a multimeter in ohms mode across the live and neutral power input, you should see a resistance.
      If not then check the power switch/voltage selector switch and input fuse.
      If the voltage selector switch is in the wrong position the primary winding of the transformer could be toast :-(
      • Leebo249
        SA-HD52 1 Default Crosstalk/static after replacing selector switch IC?
        by Leebo249
        Hey,
        A month back I replaced the selector switch IC on my Panasonic SA-HD52 as the radio was still playing when I selected the CD, it did this with the tape and record too.
        Now when I replaced the IC it worked perfectly, no cross talking and I left it at that for a month and have come to it today to play a CD (you can hear it spinning) and the issue has come back although with another issue.
        Both issues are random, the original problem where the radio will play over other playbacks has come back and another time you turn it on it will refuse to play anything,...
        09-07-2025, 07:23 AM
        ME Firmware Cleaning Guide
        by SMDFlea
        Here`s a quick ME Firmware cleaning guide.
        The guide is basic,its main goal is to show you how to use intel FIT,its highly recommended that you all follow the guide posted at win-raid
        (The attached FIT version is 11, if your ME Firmware (FW) is not 11.0.*.* follow the win-raid guide. Use the tools version for your ME FW, for example: ME System Tools v9.1 For systems running ME v9.0 - v9.1)
        A video,software (intel FIT) and practice bios are all included. I`ll post a better video and more advanced guide at a later date.
        1. Open the...
        09-09-2020, 09:10 AM
      • ktmmotocross
        ps5 bv, schem or repair guide
        by ktmmotocross
        Have this PS5 EDM-033 with one beep. error is some short but i dont find one on main rails. need schem or guide to check all rails
        I would like to have BV, schem or repair guide so add them here
        07-02-2025, 11:57 PM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • ktmmotocross
        Steamdeck schem, bv, or repair guide?
        by ktmmotocross
        I have this steamdeck T101
        hat looks like slow charging/only 3.5W/ but not start. anybody have schem, bv, or repair guide for it?
        also can steamdeck work without battery, just on USB-c power?
        06-30-2025, 12:25 AM
