I have two older 40w American Power Supplies that all the wiring comes out as a bundle. I would like to buy the female socket plugs th mount in the power supplies and the male plugs that attach to the wires. Of course I need the corresponding male and female wire connectors that crimp to the wires. Does anyone know where to buy them or have any part numbers?
Making a Computer PS modular
RJ45 Block Diagram / Schematic
RJ45 network connectors are most commonly found at either end of an Ethernet (wired internet) connection. At first glance, they appear similar to the familiar telephone plugs and jacks which connect landlines to walls or switchboards. However, RJ45 connectors are typically slightly larger.
The term RJ45 connector is widely used today to describe both male RJ45 plugs and female RJ45 sockets. The plugs, sometimes called modular connectors, are usually found on the end of Ethernet cables. The sockets or jacks are generally embedded in the device...-
Channel: Schematics and Boardviews
10-31-2024, 04:18 AM -
by howardc64Samsung have been using this style LED connector for few years now
Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open... -
by CapLeakerPatient: Norstar - Plus modular ICS NT7B62FA power supply.
Complaint: Doesn't power up anymore. It did work for a short while, next morning dead?
U1 (UC2844) Vcc pin jumping up and down between 10V and 15V. Vcc supply resistor 51.1k and capacitor 100uf 40V is o.k., but jet there is nothing coming out on the other end. Secondary is producing nothing, no shorts, nothing visible.
Replaced U1 (UC2844) with a new one, powered the PSU up on the bench and the LED started to blink faintly. Plugged the PSU card back into the Norstar modular ICS and all is working... -
by wenl619Intel (R) Modular Flash Image Tool. Version: 18.0.10.2285...
I bought "ADATA C008 / 16GB" USB Flash Drive yesterday, and I'm curious about meaning and usage of this 10-characters number and 4-charatcer string on USB Standard-A, "male" plug.
- Loading...
