RYOBI-one charger
  • simonmpoulton
    • Aug 2012
    • 12
    • united kingdom
    Re: RYOBI-one charger
    sure model is BCL14181H and upon closer inspection of chip in question under the microscope i can make out the code 6853i34. I cannot seem to find any data sheet for this though!
      • 31065
      no, SP6853
      https://www.aliexpress.com/w/wholesa...rchText=sp6853
      • R_J
        • 9551
        sp6853 data sheet
        • simonmpoulton
          • Aug 2012
          • 12
          • united kingdom
          Ok yes that's it thanks but is there any compatible part code which is available from a UK supplier or is China the only option?
            • 31065
            try Maplin?
            lol
            no, china is your only option.
            or cheapest anyway, you may get it from germany(Reichelt), poland(TME) or the u.s.
            i didnt check those sellers btw, i just know they have impressive range of stuff.
            • simonmpoulton
              • Aug 2012
              • 12
              • united kingdom
              #26
              Ordered from china so now the wait begins - a few of the resistors around it don't look great either do you know the values?
                • 31065
                no, but you can usually read them even if burned.
                check the ceramic caps too - incase of a shorted one.
                • simonmpoulton
                  • Aug 2012
                  • 12
                  • united kingdom
                  #28
                  ok finally got my IC's from china unfortunately still no go - there appears to be a short on the output side of the transformer. All pins on the output of the transformer appear to be shorted to the negative battery terminal. I've checked and cannot see any obvious sources for this short - any pointers?
                  • R_J
                    • 9551
                    Yes, one end of the transformer is connected to ground, the other end of the winding should go to a diode, then to a capacitor, and eventually to the output
                    If you measure the DC resistance on the transformer pins The winding itself will be very low, lees than 1Ω
                    Check the resistance of R2, R3, R4, R7, R8 & R9 and the large grey resistor between the transformer and fet
                    EC2 cap may also need replacing
                    You did install the ic the right way?
                    Using the large main capacitor's negative as ground, check the voltages on the ic, carefull don't slip with the probe.
                    Also when you said the mosfet blew up did you mean the one in the primary or Q2 in the secondary?
                      • 31065
                      re-read the whole thread and check the smd fet and the big schottky diodes.
                      • simonmpoulton
                        • Aug 2012
                        • 12
                        • united kingdom
                        #31
                        IC Installed correct way yes - I will check the resistances of the resistors mentioned later and report back. I'll also attempt to check the input voltages on the IC
                        As for a recap on the original issue - main SMD fet on the secondary part was burned due to the short of one of the diodes as per original thread post. I have replaced already the main smd fet and the twin diodes as per the original thread post. Also have replaced the protection Zener on that circuit. All electrolytic caps have also been replaced. It was still no go at this point so I started investigating the issues elsewhere and found IC1 burned which is now where i'm at.
                          • 31065
                          shorted ceramic cap is possible.
                          • simonmpoulton
                            • Aug 2012
                            • 12
                            • united kingdom
                            #33
                            Ok so R2, R3, R4 were all burned - R2 very badly - had a hole in it. D1 was also burned. All replaced, The grey resistor RS1 was also burned with a hole in it. I have replaced RS1 with a 0.4Ohm Resistor - it shows as a 0.43Ohm resistor but 0.4Ohm is the closest I can find - is this likely to be an issue? I don't want to plug this in if that's going to burn something out!
                            Also BD3 was shorted - this one is a diode between what appears to be the primary side ground and mains voltage input - would probably explain why RS1 and R4 burned so badly as they would've received mains voltage! - Do you know of a better replacement for BD3 or should I look for a like for like replacement?
                            As for the ceramic caps - i've checked quite extensively around and none appear to be shorted
                            • R_J
                              • 9551
                              D1, R3, R4 are between the ic output and fet gate. When the fet Drain shorted to its gate it will supply full B+ to the gate circuit and IC ! they don't like that. R2 is the current sense feedback from the source resistor of the main fet to the ic. If the fet drain was also shorted to the source, R2 would blow. There is also a green resistor between the fet Source pin and ground, Or is that RS1? there are two of these similar resistors, that source resistor and one that goes between B+ and snubber circuit of the fet (connected to RF2 10Ω resistor)
                              Your pictures are too out of focus to make out BD3 But it is likely one of the four that make up the bridge. I would replace all four with what was there, they are not that critical.
                                • 31065
                                for the mains bridge, if 1A is enough then use 1n4007
                                what is the original part?
                                • caspian
                                  What Zener Diodes on a Linear Power Supply
                                  by caspian
                                  Dear members,
                                  I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                  Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                  In addition, I discovered that its zener diodes are defective.
                                  I can replace the burned transistors.
                                  But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                  Therefore, I cannot replace the zener diodes.
                                  I do not want to test the zener diodes in a test circuit to discover their model or value.
                                  no schematics are available...
                                  05-26-2025, 12:38 PM
                                • motormayhem
                                  Lenovo T460 Only Charges on One Charger
                                  by motormayhem
                                  Laptop Question
                                  I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                  A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                  05-12-2023, 01:46 PM
                                  NVDC charger configuration...
                                  11-05-2024, 03:28 PM
                                • flat-earther
                                  how to prevent a connected charger from draining battery when not charging?
                                  by flat-earther
                                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                  So the battery is backfeeding the charger and being drained.
                                  How can I prevent...
                                  08-07-2025, 01:04 PM
                                • flat-earther
                                  ASUS X54H laptop thinks it's always charging even with charger unplugged
                                  by flat-earther
                                  The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                  Windows also shows ''Plugged in'' when charger is not connected.
                                  This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                  Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                  If I let battery run out and say it has 3% Windows will...
                                  06-24-2025, 09:32 AM
