Repair a custom form atx posee suply
  • ehrja
    • Mar 2016
    • 19
    • México
    Hello Im trying of repair a customized form factor atx poder suply wich is from a DVR the model of this power suply is ENP-2320 and is really crowded in electrónica an also is really small
    The síntomas: fuse blown I already take out a MOSFET k2611 from toshiba wich was un short circuit but only the 5vsb is feeding
    I'll try to find the problem
    Sorry forma the por inglish Im wrigthing from muy new celphone.
    Hope someone can helpme to find the problems if I can't
    • 31304
    Re: Repair a custom form atx posee suply
    check everything the fet connected to, there are usualy resistors that burn.
    also, was the fet's GATE pin shorted to the other pins?
    if it was then the control circuits will be damaged.
    the other thing to think about is why the fet died,
    i would check the bridge rectifier and remove & test the main capacitor.
    last time i saw a bad fet, the main cap had leaked under the can onto the board.
    • ehrja
      • Mar 2016
      • 19
      • México
      Ok I'll checo that luky I have other power suply wich has diodes burned.
      That is true all the pins un the MOSFET was ushorted an obiously the controlar board of the MOSFETs must be damaged I'll check that
      Thank you for your answer.
      • ehrja
        • Mar 2016
        • 19
        • México
        This big cap is good it reads 105 uf ESR 0.26, I'm not shure about the big resistor which reads 0.4 hom
          • 31304
          sounds o.k. it's probably inline with the gate pin.
          • Stefan Payne
            • 1267
            if you can't fix this unit:
            It's a standard Flex ATX PSU, sometimes you can find similar things as 1HU server thingys...
            • ehrja
              • Mar 2016
              • 19
              • México
              I'm actually wondering if at last this power supply could be changed by a generic if not can be saved.
              I mean this power supply has the same voltages and connectors as a generic one. Just to find the way to Short the height of the tallest components that must be the heatsinks.
              I read an article that talk something about feeding the output whit an other power supply in order to check the secondary section or the regulated low voltage. Is it posible to do without damaged components?
              • ehrja
                • Mar 2016
                • 19
                • México
                is not it has a big black crack in the hidden side.
                however I notice that all semiconductors in the secondary side are shorted beter no to follow with this one.
                And I better check on the other PS, is the same model the problem almost the same just the 5vsb are on and when I pluged the atx tester all voltages are on for about half a second.
                • Teban1306
                  [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                  by Teban1306
                  Hello everyone!
                  I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                  System Information:
                  • Model: Lenovo ThinkPad T14 Gen 1
                  • Machine Type: 20S1S4E600 (Intel i7 variant)
                  • Current BIOS: N2XET42W (1.33) - Latest version
                  • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                  What I'm trying to achieve:
                  Replace the default "LENOVO" boot logo with a custom image during POST.
                  🔧 What I've tried:
                  09-14-2025, 11:49 AM
                • GuiTi
                  Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                  by GuiTi
                  Hey everyone!
                  I need help with my Lenovo Chromebook 100e Gen 3.
                  Here are the details:
                  • Motherboard: LA-L131P
                  • MFG Date: 2022/01/07
                  • MTM: 82J80001BR
                  • MO: MPNXB2103001
                  • Factory ID: LI123
                  I bought a new Winbond 25Q128FVSG chip.
                  The chip currently on the board is the same model but with different ending letters.
                  I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                  The Chromebook is Google account locked, and I’ve already tried everything.
                  I understand that I need to replace or...
                  10-14-2025, 08:41 AM
                • CammyTier1
                  Anyway to remove HP 840 G5 Custom splashscreen
                  by CammyTier1
                  Hey All, I have loads off hps all with passwords and custom splash screens is there anyway to remove the splash from bios dump well am doing the passwords on them or anyway to remove the custom splash atall...
                  11-27-2023, 01:34 AM
                • BleedCap
                  OLD Socket 478 custom bracket + NEW generic cooler
                  by BleedCap
                  I already posted this on vogons.
                  Its a 3d printed custom bracket for socket 478.
                  I used this AM4 bracket as a base design.
                  Its to be use with cheap generic clip based cpu cooler.
                  Reason for doing this is:
                  - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                  - New generic cooler is cheaper and can use bigger fan (less noise)
                  I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                  The processor that I was using is P4 2.4Ghz prescott....
                  11-05-2023, 08:09 PM
                • Caly411
                  burned mosfet wich has written on top "I6 GUE 8v1507"
                  by Caly411
                  Hi, Im having a similar problem with my Acer Nitro 5 AN517 52, took it to repair and they said that the problem was a burned mosfet wich has written on top "I6 GUE 8v1507".
                  There is written PQB12 on the motherboard right next to it.
                  Does anyone know if there is soemthing similar I can buy to replace it with?
                  Seems impossible to find theidentical mosfet online.
                  08-30-2023, 10:48 AM
