How do you test big filter caps?
  • mikay786
    • Aug 2014
    • 765
    So as of so far for big caps pretty have just been checking them for visual signs.
    Basically with my multimeter I can only test smaller caps, with big caps I cant get a reading even after leaving it attached for a while. Is this due to not having enough juice to charge cap?
    Do you need special equipment to test larger caps? Ive got a ESR meter like this ebay transistor / esr tester (https://www.badcaps.net/forum/showpo...6&postcount=50)
    but the pitch is a bit small but could solder leads to it but again I'm sure ive tried before and same issue not getting a reading on larger filter caps.
    Caps I'm wanting to test are 63v 10000uf Samsung SMS caps.
    • 31304
    Re: How do you test big filter caps?
    the esr meter should handle 10,000uF
    just make sure the bitches are fully discharged just before you test them - big caps can slowly self-charge.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      my cheap ebay transistor / esr tester test filter caps just fine ive never had any issues with testing them etc i have more trouble finding the data sheets for the correct esr reading.
      • mikay786
        • Aug 2014
        • 765
        Cool will try the esr meter, yea I made a discharge tool using a cheap probe with crock clip on one end and probe in other, cutting it in half and soldering in a big encapsulated 5w resister in between and heat shrinking it.
        Does the job nicely, about 25-30 to fully discharge big caps. Surprising though even with under 1 volt left in a big cap I shorted it with a screw driver and still got a spark. So now keeping it on longer and then shorting to make doubly sure.
          • 31304
          it's the ripple current that gives the spark.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            I should make a discharge tool can i use a 5w 100k cement resitor as i have some spare.
              master hoarder
              • May 2008
              • 12175
              Actually, from what I've read before, it has more to do with the energy stored in the cap, which is
              0.5 x capacity x voltage^2
              with capacity in Farads and voltage in volts.
              And the ESR matters a lot too, of course - two times lower ESR can often double the current at short-circuit.
              I usually discharge my high voltage caps (up to 450V) with a 4.7 KOhm 5W resistor for a few seconds. If the cap has only a few volts left on it, I short-circuit it with a screw driver.
              Indeed.
              Which is why I always try to keep mine fully charged when in storage - that way, it becomes a habit of discharging them first. And believe me, I thought myself that habit the hard way - those HV caps will bite if not careful!
                • 31304
                crt's are the best caps.
                hmm - gives me an idea, next time i have one exposed i'll try to put it on the component tester!!
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                  by momaka
                  03-15-2023, 10:17 PM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                  Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                  by momaka
                  This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                  Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                  Macron Power Technology Co. LTD.
                  Let’s look at the PSU itself.
                  The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                  06-02-2021, 10:05 PM
                  by momaka
                  03-12-2025, 03:42 PM
