Need Advice to use the good power supply laptop
  • HABIBOU11
    • Jul 2015
    • 50
    • ALGERIA
    Salam aleykum ;
    i have a dell laptop that supports 19V 4.62A adapter & I Use 19.5V, 6.62A
    this will be risky for my laptop ?
    Хвала Аллаху, Господу миров
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Need Advice to use the good power supply laptop
    I don't think the extra half a volt will be risky, but Dell use the centre pin of their charger to detect that it is genune. If it doesn't detect the genuine charger it should power on but not run at full speed.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      The extra .5 volts shouldn't cause any problems. And remember that the rated amperage is the maximum the power supply can output. If the laptop only needs 4.62A its not going to "force" more amps in. You could use 19V 1000A power supply with no issues, for that reason.
      • HABIBOU11
        • Jul 2015
        • 50
        • ALGERIA
        thnax a lot
        • ivtec
          • Dec 2008
          • 1967
          Originally posted by HABIBOU11
          Salam aleykum ;
          If you read 19.5 instead of 19v it's ok, most transformers read more v without load,i have here an HP adapter that is 19v but when i test with my DM i see 19.16 v,and this goes for most adapters that i have and i have many in my scrap,without load some adapters get more volts, this is normal,although some good Q adapters should have lower variation,i also have a small adapter that is 1.5v but when i probe the output i read 6v.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            It shouldn't cause a problem.
            If anything, it's slightly better because the extra half a volt will compensate for the resistance in the power cord when it is heavily loaded.
            -Ben
            Muh-soggy-knee
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
            • Bloodhoundje
              HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
              by Bloodhoundje
              I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
              I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
              After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
              I have desoldered the bios chip (GigaDevice...
              03-16-2024, 03:12 PM
              by sam_sam_sam
              03-31-2024, 02:12 PM
              Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
              This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
              09-06-2024, 09:30 PM
