10mm Power Supply Capacitors
  • bgavin
    • Jan 2007
    • 1355
    It seems the vast majority of PSU are using 8mm and 10mm craps such as TEAPO, OST, and Fuhkyoo. Finding quality replacement caps in these diameters is proving difficult. Specifically, I am looking for 16v/2200, 10v/3300.
    These series can match the 10v, 16v diameters
    Rubycon: PX, ZL, ZLG, ZLH
    Samxon: GC, GD
    I understand Rubycon recommends their Zxx series for power supply use. I don't know about the Samxon GC,GD series.
    Q1: Are the above Samxon optimal for PSU use?
    Q2: Anybody have a source for the Rubycon Z series?
  • kikkoman
    • Jul 2007
    • 691
    Re: 10mm Power Supply Capacitors
    re Q2: Farnell usually stocks ZL, ZLH and ZLG. Not exactly cheap, though.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • linuxguru
      • Apr 2005
      • 1564
      Pansonic FJ 1800uF/16v/10 mm is an excellent choice for the 16v rail. It helps if there are two caps on that rail for a measure of redundancy.
      The other substitution is harder - I tend to use NCC LXZ 2200/6.3v/10mm inboard of the pi-filter, and Nichicon HM 3300/6.3v/10mm outboard, if there's sufficient air-flow. Or try to shoehorn a 12.5 mm cap in one or more locations.
      • bgavin
        • Jan 2007
        • 1355
        Here in the states I am limited to what is financially feasible. Farnell is not feasible. The prices are simply too high, and shipping is awful.
        Wai Fong in Hong Kong is OK, but their stock is terribly limited. $20 USD for FedEx is OK, if one buy sufficient product to make it worth while. I get a good price break on 200pc bags.. but that is a lot of caps for somebody who is not doing this full time. The 50pc bags are higher unit price, but affordable.
        I have to check with Big Pope, as the Samxon GC, GD look like good prospects.
        • Big Pope
          Approved Vendor
          • Dec 2005
          • 426
          Samxon: GC, GD
          I used Samxon GD/GC in power supply for a few years, there is no any problem till to now. Besides, now Samxon GT/RS available in D10mm 10V2200uF, 16V/2200uF, 10V 3300uF and 16V 3300uF.
          Samxon GT and RS both ae long life series, will be more reliable if anyone worry about the life for GD/GC in power supply or LCD monitors.
          My SAMXON Capacitors Database HERE!!
          X-CON is a new brand for SAMXON's Polymer Capacitors.
          • bgavin
            • Jan 2007
            • 1355
            The GT looks like the better choice for power supplies, yes?
            I'm looking for *the best* series for power supply use.
            • Big Pope
              Approved Vendor
              • Dec 2005
              • 426
              If you ask me this question, i will reply you yes, it is the best series of Samxon for power supplies.
              I am planning a event for Samxon GT as replacements for many LCD monitors which infected by issues Samxon GF. Of course it is free of charge, like a testing events for public. Please a few days.
              • bgavin
                • Jan 2007
                • 1355
                Your web data base shows GT caps for 16v / 2200uF in 10mm diameter, but the data sheets only show 12.5mm x 25.
                If you have GT 16v/2200 in 10mm, please let me know.
                • Big Pope
                  Approved Vendor
                  • Dec 2005
                  • 426
                  Yes, factory can custom made GT 16V/2200uF in D10mm.
                  • bgavin
                    • Jan 2007
                    • 1355
                    A custom build is OK for a power supply manufacturer ordering thousands of D10mm Samxon instead of using TEAPO, but it doesn't help me. I only order about 200pc of a given capacitor.
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      • USA, Unsure of Planet
                      Newark Electronics carries some Rubycon, including ZL series parts.
                      PeteS in CA
                      • bgavin
                        • Jan 2007
                        • 1355
                        I am going to place a custom order for Samxon GT in the sizes I need. The price is acceptable when purchased in bulk. Frankly, I'm amazed the factory can accomodate small custom orders... but I will certainly take it.
                        Finding top grade PSU caps in 10mm is difficult. I have to disassemble a new PSU to determine the final cap value, which is an 8mm diameter. I did make a score on 12.5mm ZL and 10mm MBZ stock, but neither will work in my PSU of choice.
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                          03-31-2024, 02:12 PM
                          07-01-2024, 06:34 AM
                        • shamsudeen
                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                          by shamsudeen
                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                          07-19-2025, 07:14 AM
                        • JimBanville
                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                          by JimBanville
                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                          09-13-2023, 07:21 AM
