I have a dead Thermaltake TR2 RX-550. This one has me stumped! Fuse OK, 166 volts to the main capacitor, but no 5vsb. For the 5vsb circuit, it has a 6 pin pwm surface mount chip on the bottom of the pc board which drives a TO-220 transistor. I cannot identify this chip. Can anyone tell what it is?????
Thermaltake TR2 RX-550 dead
Re: Thermaltake TR2 RX-550 dead
I went looking for something like that for a TV power supply. I picked the R7731A from this selection.
http://au.element14.com/webapp/wcs/s...4239,111853290
I found parts from many other manufacturers that would have worked also.
The choice was between two basic types where the difference was the function of pin 3.
With one type, pin 3 is for connecting a resistor to set the frequency. Pin 3 on the other type is to connect a thermistor for thermal protection. Send us a close up photo of the surrounding components.Last edited by rievax_60; 12-22-2015, 08:55 PM. -
is used for a frequency setting resistor.Comment
by delturciousI have an older Thermaltake PSU that has a squealing noise whenever it's plugged in, even when totally disconnected from everything else. It automatically powers on the 5V and 12V rails with full voltage, but the +5VSB circuit only has 0.9V on it. I would assume this is my first place to start troubleshooting?
There is nothing obviously burnt/leaking that I can identify.
I've tried to take some decent photos of the 5VSB area. Components of notes:- U8 at the back is marked AZ431
- C38 is 102
- C47 is 104
- C34 is a Teapo 330uF 16V (I think all the cylindrical caps are
by double_DDHi all,
As the title suggests, how can I be sure that my EC chip is really dead?
I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard... -
Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
Securing a good thermal interface between...-
Channel: Common Parts Library - Datasheets
10-07-2024, 04:35 AM -
by прямоSo I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...3 Photos -
Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
Any ideas where to go next? - Loading...
