Arer these caps ok to go into PSU?
  • mikay786
    • Aug 2014
    • 765
    So ive got an old PVR here which looks to have bad caps in the power supply side. Chang / G-Luxon with a few bloated.
    So I have tried to be proactive instead of begging others to do the help right away and have put together a list from farnell of some with matching specs, but im pretty sure Ive not chosen wisely on a few. I think the FR series ones will be fine but some of the others not so.
    1800637 4 1000UF, 16V, RAD EEUFR1C102
    1800671 2 1000UF, 35V, RAD EEUFR1V102
    1907238 1 1000UF, 25V, RAD EEUFR1E102
    1800677 1 100UF, 50V, RAD EEUFR1H101
    1907235 5 100UF, 25V, RAD EEUFR1E101
    9696652 5 47UF, 50V, RAD ECEA1HN470U
    8767483 1 10UF, 63V, RAD ECA1JAM100X
    8767246 1 47UF, 35V, RAD ECA1VAM470X
    So the bottom three don't look so good? the uf/v and size of them all are matching or close enough. Just not sure if the bottom 3 are suitable for power supply? A couple look to have no polarity too which I didn't notice at first.
    • 30991
    Re: Arer these caps ok to go into PSU?
    use FR for all of them.
    • retiredcaps
      • Apr 2010
      • 9271
      If FR is not available in the available uF or V or size, try FM series. If no FM, then go to FC.
      PS. Just make sure your PVR is discharged. See my experience with one.
      https://www.badcaps.net/forum/showthread.php?t=41319
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        Questions framed like yours will result in many more people likely to help you.
        So refreshing rather than the usual
        Help me. xyz is not working, I have no clue what to do. Urgent.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4951
          • New Zealand
          To be fair, some of those people are clueless and have no idea where to start. They just stumbled on the forum through Google, don't know anything about electronics, and think other people have some instant and magical knowledge of their exact problem...
          -David VanHorn
            • 30991
            if it's like that then i'd solder a 1meg resistor across it - just make sure it's rated for 400v minimum.
            • mikay786
              • Aug 2014
              • 765
              Yea I was surprised how much charge it had stored, I think it was 244v I measured. So just shorted it out with a screw driver and got a little mini spark.
              I forgot to check forum in morning and just went ahead and picked up the above listed caps! Isnt a issue as I can just change the FR ones for the time being and order some others.
              But I wanted to ask could I get away with using
              Cant be any worse than the chang and teapo's. Its free delivery so can just order some others if they are not suitable.
                • 30991
                dont discharge large caps by shorting, you can damage them internally.
                the wires inside arent thick enough for the current some can hold.
                • mikay786
                  • Aug 2014
                  • 765
                  just changed over the FR ones and we have life. Might not bother doing the other little ones.
                    • 30991
                    good.
                    what make / model is it btw - most dont have many caps in the psu anymore.
                      by momaka
                      03-12-2025, 03:42 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
                    • Foetuss
                      Gigabyte GA-6OXT :: caps question
                      by Foetuss
                      Good evening
                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                      But I was also suprised about the bigger boys, which are 330µF 25V.
                      Could it be they used 25V caps because they were cheaper / available at that time?...
                      02-11-2025, 12:22 PM
