Questions about half bridge BJT driving
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Some questions:
    1. What is the purpose of the extra winding on the GDT? (Circled in red) Does it have something to do with the crossover? (I.E. making sure that both transistors aren't going to be turned on at the same time)
    2. Are C7 and C8 (green) there to turn the transistors on and off faster? What would be the purpose of the diode and resistor in series with them? To discharge them?
    3. What are R2 and R3 (orange) doing? They certainly don't allow enough current to flow to be turning the transistors fully on.
    -Ben
    Muh-soggy-knee
  • japlytic
    • Oct 2005
    • 2086
    Re: Questions about half bridge BJT driving
    1: The winding circled in red is used for current sensing.
    2: C7 and C8 help speed up turn-off timing while D12 and D13 help speed up turn-on timing.
    3: R2 and R3 are startup resistors, since this design has the PWM controller on the secondary side but not on the primary side.
    • rievax_60
      • May 2012
      • 897
      • australia
      The winding circled in red is for current feed back into the driver transformer. It causes the Base drive current to Q1 and Q2 to increase with increasing load current. This keeps the transistors in saturation at high load currents and prevents the drive current from being unnecessarily high at low load. When BJTs are driven too hard, they become more difficult to turn off quickly.
      • rievax_60
        • May 2012
        • 897
        • australia
        Q3 and Q4 supply very little drive power into the driver transformer. They only supply an initial turn on pulse to the output transistors, then the feedback current takes over.
        During the dead time, Q3 and Q4 are both on, short circuiting the primary of the driver transformer, holding Q1 and Q2 off. Q3 and Q4 alternately turn off to cause Q1 or Q2 to turn on.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Thanks for the explanations!
          -Ben
          Muh-soggy-knee
          • madan1
            Troubleshooting half-bridge smps
            by madan1
            Hello everyone, I'm trying to fix what seems to be a half-bridge smps.
            The switching controller is sg2525a, which I have replaced with a brand new sg3525a. The low and high mosfets are 1c27ac 6n50. The mosfet driver is IRS2301S.
            Both mosfets were tested outside circuit with a component tester and seem to be fine.
            With oscilloscope I see ~65khz switching signal on both low and high outputs of the controller, but on the output of the mosfet driver there is switchig signal only on the low output (flat line on the high output).
            So I guess the mosfet driver is faulty?
            01-23-2025, 06:05 AM
          • semiRocket
            Toshiba 37bv701b power supply main rails
            by semiRocket
            The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
            I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
            Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
            10-26-2025, 01:55 AM
          • Ross Kohler
            Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
            by Ross Kohler
            I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
            - There's no sign of any attempt to power on when pushing the power button.
            - No PSON signal is reaching the 24-pin ATX connector.
            - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
            - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
            - If I pull the Super IO S_SLPS#_R pin...
            04-16-2024, 09:36 AM
          • kevin_allein
            Samsung GU58TU7199 reboot loop
            by kevin_allein
            Hi, I have two identical Samsung GU58TU7199, which both had the reboot loop. On that model TCON is integrated into the motherboard and there is only one FPC cable, which goes to a driver board driving half of the panel (left side seen from the rear of the TV) and than another FPC cable connecting left side to the right side.
            The first one was easy, once I disconnected the FPC between left and right the TV did start up. I soldered a bridge on the motherboard on the test points as found here in the forum or on Youtube and half of the screen was coming up. I than tried the CK1..8 lines...
            03-24-2024, 12:19 PM
          • bauto601
            KDM 480W PSU upgrade succes! (opinions?)
            by bauto601
            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
            A "nice" YoungYear unit? - Badcaps
            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
            12-26-2023, 03:05 PM
