Prudent Way PWI-PR350 Rebuild
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    I don't think I ever posted this thing. I got it a long time ago. I think May, 2014. It looks like a decent 350W, even before I modded it. And I did, but those pictures will come later. Here's how it looked stock
    6A bridge
    680uF input caps
    TO-247 13009 switchers
    IC for 5VSB
    40A on 5V
    30A on 3.3V
    two 20A ultra fast on 12V
    nice 12.5mm cap slot for 12V
    Young Lin DFS122512L fan
  • c_hegge
    • Sep 2009
    • 5219
    Re: Prudent Way PWI-PR350 Rebuild
    Not too bad at all. It should be capable of 350W in spec.
      master hoarder
      • May 2008
      • 12175
      Looks pretty good indeed. The heatsinks in combination with that 12 cm fan should definitely be able to hold up to at least 300W. I think it will make it to 350W no problem.
      What's with the darkened area around the resistors on the secondary side near the 5VSB transformer and PWM controller, though?
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Yeah doesn't look bad for a budget 6 year old unit. It was made in March, 2009. I think so too. It looks similar to some of the units that you've reviewed.
        Yeah it's a nice fan too! It was getting a little dry, so I oiled it. I'm not sure what's up with those resistors. When I recapped it, amazingly all of the caps tested good! Even the BH caps on the 5VSB filtering. Both those were 1000uF 16V CD288 series. They were failing though, one of them tested 1,168uF. Here's the crappy thing though. I originally started working on this unit when I first got it, so I started pulling caps to test them and started removing glue. Because of my short attention span, I found a "more interesting" project and started working on that one. This one sat to the side for a long time. I remembered all of the values except the ones for the base drive circuit for the switching transistors. I know they were those red nicon caps, but I can't for the life of me remember their values, or find them in all of the caps that I've pulled and kept. I guessed 4.7uF 50V and installed those. The PSU runs but it creates a quiet high pitched whine at any load, either on or just 5VSB. I'm thinking I might have used the improper value, and in turn changed the frequency at which the circuit operates. If I did use the incorrect value, is this the likely result? I knew it was either going to be 2.2uF, 4.7uF, or 10uF. The pitch doesn't seem to change as the load changes. I used one of the red nicon caps in a silly experiment project. That would have the correct value but I'd have to find the darn thing
        Besides that, I replaced all of the other caps, added MOV's, upgraded the input caps from 680uF to 820uF, removed all the glue the best I could, wired the primary permanently to 120V, added a 6 pin PCIe connector, and changed out the minimum load resistors on the output rails. None of the new ones were lower than 100Ω. I'm still on the fence on whether or not I should change the 12V rectifiers. Two 20A ultra fasts isn't terrible, but I was thinking that if I changed them to two 30A schottky rectifiers, the 12V would run too high unless there was a heavy load on it.
        Edit: I also wonder what those jumpered resistors are for on the secondary next to the 12V wires. I wonder if that's their take on OCP?
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          From my experience those capacitors usually are 4.7uF, 2.2uF or 1uF and rarely 10uF.
          Don't hesitate to replace them with 2.2uF and test it. I have seen the same psu (Jou Jye 400W) using 1uF caps in 2004 revision and changing them with 4.7uf in 2005 revision and newer.
          edit: c_hegge is right, didn't notice that.
          • c_hegge
            • Sep 2009
            • 5219
            If it squeals with only the 5vsb active, then it's got nothing to do with those caps. Those are used on the main switching transistors and are only used when the PSU is actually running.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              No UL number! Can't tell what OEM it might be. (if it isn't designed by "Prudent Way") The layout looks familiar. (Especially with the 4 caps in a square shape on the secondary, instead of being staggered to fit them in a smaller area)
              Does it feed the fan 12V, or is it speed/temp controlled?
              Happens to me too
              Hm, it might be the 5VSB that is doing that. Perhaps you used a cap with too low of an ESR? It might have done that since it was made. Maybe they didn't get the compensation network(s) correct.
              Muh-soggy-knee
                master hoarder
                • May 2008
                • 12175
                Exactly.
                The squeal is likely from the 5VSB circuit. Now this may or may not be something to worry about. Here's why:
                5VSB circuits usually employ flyback topology (i.e. no output inductor), regardless if it's a chip or 2-transistors circuit. Actually, many TVs and monitors (both LCD, CRT, and LED) regularly use this topology, among many other devices. And from what I remember reading a while back, since there is no output inductor, the ripple current on the output of such PSUs is usually quite high. Therefore, it is actually possible to use very low ESR and high ripple current caps on these PSUs without problem - even polymers. Now, I can't tell you why (because I don't know either), but this often results in a high-pitched squeal. I wouldn't worry about it though. I have seen this both from factory-made PSUs that used low ESR caps (such as Chemicon KZE) and through my own experiments. Almost all of the LCD monitors that I recapped with Panasonic FR and FM (and in one case also tried Rubycon MCZ) would produce a high-pitched squeal afterwards. But output voltages were stable as a rock - much more than with the stock crappy caps - so I left them alone.
                There are cases, however, where that high-pitched noise could indicate a problem. It depends how the 5VSB feedback is implemented. Normally, most PSUs just take the 5VSB, run it though a half-half resistive divider, and connect it to a 431 shunt. But I have also seen a half-bridge PSU where they took both the 5VSB and the secondary side auxiliary rail from 5VSB and used a combination of both for feedback. So that's why it is usually important to recap both the output of the 5VSB rail and the secondary auxliary rail.
                Looking at the pictures you provided, I think you already did that (brown UCC KY/KZE cap on the 5VSB rail and a small Panasonic FC? cap next to it). So in that case, I think you should try to measure the voltage of the secondary side auxiliary rail. Should be 10-20V without load on the 5VSB. With load, it may go up to 25V - it varies quite a bit between different PSUs, though, so I can't give you concrete numbers. Just make sure that even with a heavy load on the 5VSB (like 1 to 1.5A) that the secondary side auxliary rail's voltage does not go over the voltage rating on that Panasonic FC cap you used. In some cases , I've seen improperly specced caps on that rail pop (*cough* Deer *cough* ).
                The secondary side auxiliary rail on your PSU comes out of that smaller diode next to the bigger diode for the 5VSB. The 5VSB diode appears to be labeled "5D3" on the board. There is a smaller diode just behind it, using this picture as a reference:
                https://www.badcaps.net/forum/attach...3&d=1432017436
                From what I can tell, it is possible that Q4 and those overheated resistors are used for some kind of linear voltage regulator for the controller. So that may be why they run so hot.
                Or it could also be that they overheated if the PSU had bad caps on the output of 5VSB and before you recapped it - especially if it was used like that for a bit.
                So just check the voltage on the secondary side aux. rail, just to make sure it's not up to something funny. Again, its voltage should stay under that voltage rating of that Panasonic FC cap, even with moderate 5VSB load. And hopefully, not higher that 30V. Even 25V is a bit on the high side.
                I am just curious if it's the 5VSB design or bad caps on the 5VSB that caused those resistors to run hot like that.
                • Behemot
                  • 4845
                  • CZ
                  Leadman, Sun Pro or something like that. They have been labeled as Eurocase here. Not worst but not wonder either.
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Don't hesitate to replace them with 2.2uF and test it. I have seen the same psu (Jou Jye 400W) using 1uF caps in 2004 revision and changing them with 4.7uf in 2005 revision and newer..
                    You rarely see 10uF there? Hmm, seems to be fairly more common in my experience. I think 1uF seems more rare.
                    Alright, I'll test it again just to make sure I was remembering correctly.
                    It's actually made by XHY Power http://www.xhy-power.com.cn/
                    It's speed/temp controlled, and it's very, very quiet. Such a relief
                    Very interesting. High ripple circuits, is this why they need a CLC filter even for such low loads? That would explain it, and why certain Leadmans have stupid amounts of ripple. Yeah, I've heard factory PSU's do that too. I'll have to measure the voltage again and see what it was reading.
                    Yeah, and those darkened resistors might indicate a problem, or that there was one at one point with the possible bad/failing caps. Maybe the caps actually went out of spec when the load was increased on that rail. Pretty hard to trust BH caps It does look like a unique 5VSB design. Also, I found it weird how far away the 5VSB filtering caps were away from each other. The most annoying thing about this power supply was the glue! See how I had to remove the main IC to remove some, along with all of those little components.
                    Yeah, they're Chemi-Con KY 1000uF 10V before the coil, and 680uF 16V after the coil. The Panasonic FC cap is 47uF 50V. Thanks for sharing your knowledge with me. I will measure it when I find the thing. I think I know where I packed it
                    I'll let you know I'm willing to guess that it was from the poor shape of the BH caps. I'll also let it run with some load and get out my infrared thermometer to see how hot that section of the supply gets after a while.
                    Anyone have any idea why they used wire to fly that coil all the way to the feedback transformer?
                      master hoarder
                      • May 2008
                      • 12175
                      Yeah, I find 10 uF to be more common as well. Maybe it's because we are used to seeing Macron PSUs . Although IIRC, L&C/Deer/Allied also uses 10 uF caps for those.
                      Could be. I'm not entirely sure. In general, though, wherever you need to filter a high frequency circuit without much loses, a CLC filter is used. If loses are not a problem, you can do RC. The one thing you probably won't see on a flyback topology is a big inductor before the caps (i.e. LCLC). The primary side of the transformer servers as the output inductor, that's all I know.
                      Well let's Be Honest here - BH caps are crap.
                      Most welcome!
                      Some kind of OPP?
                      My guess is they are *trying* to pick up stray flux from the core of the feedback traffo. But I somehow doubt that will work. If this really is for OPP, I will be very surprised if it works at all.
                      Which pins does it feed to on the PWM controller and what is the PWM controller?
                      *edit*
                      Never mind that last question. I see that the controller is an Az7500b (?)
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Yep, that's probably why Same with Super Flower half bridge units.
                        It sure seems that way. Looking at c_hegge's review on the MPT-301 though, that thing handled 2.98A on the 5VSB, was running at 4.97V, and only had a max of 20.8mV when running at the max label ratings, and 27.4mV when being overloaded. Impressive! They use an abnormally good filter for the 5VSB though. Good sized PI coil, and a 2200uF cap before and after it.
                        I'm impressed though that all the filtering ones were okay on 3.3V, 5V, and 12V. One of the 2200uF 10V caps on the 3.3V was next to a 33Ω resistor, and the side of the cap had that "charred" look right next to where the resistor was. It tested 2236uF and 0.02Ω ESR
                        Some kind of OPP?
                        *edit*
                        Yeah it's an AZ7500BP-E. None of the coils' leads are directly connected to the 7500, but one is connected through that resistor with the black marking underneath it (stupid how they put the component numbers UNDER the components) and it's connected to pin 16 on the IC which is 2IN+
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Okay so I was wrong about one thing. It's not a high pitched whine, it's a dull buzzing sort of sound. Almost similar to those old school fluorescent lights in old buildings. With power plugged in, 5VSB runs at 5.13V. When just turning the PSU on with a paper clip, the buzz gets slightly louder, and 5VSB stays at 5.13V. When the PSU is just plugged in, there is about 9V going through the auxiliary cap. When turning on via just the paper clip, there is about 23V going through the same cap. Both voltages start a little higher, then quickly lower to the other voltages.
                          Edit: I forgot to add that when pulling out the paper clip, the buzz became pulsating, and almost beep like until the main capacitors drained, then went to the more quiet low buzz.
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            You could try changing the compensation network for the feedback. That's really the only suggestion I can think of.
                            Let's Be Honest, they are Brutally Horrible, always Bulging Here and there.
                            -Ben
                            Muh-soggy-knee
                              master hoarder
                              • May 2008
                              • 12175
                              Well, the voltage appear normal. Perhaps the swing on the auxiliary rail is a tad bit larger than what I normally see. But it should be fine. As long as those toasy-looking resistors don't run super hot anymore, I think it should be okay.
                              Probably not worth messing with it. Not unless you really want to experiment "in the name of science", if you know what I mean . And it would be best to have some kind of load tester and of course a dim bulb device to make sure everything goes smoothly if you do experiment.
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                I agree, though I don't think messing with the feedback compensation could make the power supply blow up, unless you change the feedback voltage itself (basically, changes the voltage the supply regulates the output at).
                                But if you have good hearing like me, then I don't appreciate high pitch whining. However I can tolerate buzzing, like in this case. :P
                                -Ben
                                Muh-soggy-knee
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  Thanks for the replies! It seems like there is nothing wrong with the 5VSB circuit. By the way, I found that project where I used the nicon caps. They were indeed 4.7uF 50V, so turns out I guessed correctly
                                  -Ben
                                  • lti
                                    • May 2011
                                    • 2557
                                    I just noticed the umlaut in the brand name (Prüdent Way). That makes it better, right?
                                    The soldering doesn't look good.
                                    BH caps seem to have inconsistent quality. They can sometimes handle some abuse and last a long time.
                                    • прямо
                                      Viper22A 5VSB circuit
                                      by прямо
                                      So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                      In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                      01-13-2024, 07:05 PM
                                    • kotel studios
                                      FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                      by kotel studios
                                      Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                      Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                      I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                      Any ideas where to go next?
                                      02-23-2025, 11:47 AM
                                    • mrcliem
                                      CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                                      by mrcliem
                                      Hello...
                                      I got my self a dead CM V700 PSU, with nothing on +5vsb
                                      I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                                      As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                                      The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                                      I have read the datasheet and and still can not...
                                      06-29-2023, 08:18 AM
                                    • socketa
                                      Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
                                      by socketa
                                      Rescued this one
                                      Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
                                      Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
                                      The 5VSB drops to 2.5V when it 'shuts down'
                                      And the voltage across the primary cap falls from 335V to 330V at the same moment
                                      I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
                                      12-20-2022, 03:06 AM
                                    • ledro
                                      Tuxedo InfinityBook Pro 14 Gen6 - bios request/rebuild
                                      by ledro
                                      Hello, I have a Tuxedo InfinityBook Pro 14 Gen6 model PHxTxX1 laptop, which starts but does not display an image.
                                      Can someone help me rebuild this bios? I posted the old bios and the official update from the manufacturer's website.
                                      MB : MBPPH4TUXA-1P11
                                      SN: 2106SN00887...
                                      10-10-2025, 03:58 AM
