Apple IIe DynaComp power supply - capacitor identification and repair advice needed
  • yggg
    • Feb 2015
    • 5
    My Apple IIe power supply unit, Dyna Comp variant from 1984, had a cap failure recently, Kemet/RIFA PME271M EMI/RF X2 ones to be exact.
    As I went in to replace those with new ones, I noticed that a couple of capacitors nearby seemed chipped or cracked and I can't readily identify them *see attached pics*. They seem to be Mullard ones after a quick search on Google, but I'm not really sure... Any ideas on what I could replace these with?
    Also, while I'm at it, should I consider recapping all the electrolytic ones? They are all original and ~30 years old, but none seem to be leaking or bulging right now. Any ideas or thoughts?
  • japlytic
    • Oct 2005
    • 2086
    Re: Apple IIe DynaComp power supply - capacitor identification and repair advice need
    Welcome, yggg!
    The first capacitor: Brown (1) Black (0) Yellow (x10000) White (10%) Red (250V DC) - 0.1uF 250VDC 10%
    The second capacitor: Brown (1) Black (0) Green (x100000) White (10%) Red (250V DC) - 1uF 250VDC 10%
    You can use 400V or 600/630V units if you are still unsure.
    As I said elsewhere, the Rifa/Miniprint X-class units are known to be unreliable.
    • yggg
      • Feb 2015
      • 5
      japlytic, I really appreciate it!
      I wasn't sure if the red color at the bottom of the caps meant a voltage rating of 250 VDC or VAC. But you're right, it is VDC and I could always go with a higher voltage rating. I plan to use Vishay MKT368 caps to replace these two as I think I found some where the lead spacing is fairly close.
      Still, any thoughts on whether I should recap the electrolytic ones? There are about a dozen of those and I could save by ordering new ones for those as well.
      Thanks again!
        • Jul 2011
        • 6070
        If were up to me I just recap it
        • PeteS in CA
          • Aug 2005
          • 3586
          • USA, Unsure of Planet
          I wouldn't think of Rifa PME271 (I'm pretty sure the "M" refers to the 20% tolerance) X-caps that failed after 30 years of whatever line surges they absorbed there in North Carolina as poor reliability. Quite the opposite! Pretty much any brand and dielectric type will fail after lots of years and surges as an X-cap.
          Anyway, the lytics ... replacing 30YO O/P capacitors would probably be a good idea, though you should be careful not to get parts whose impedance is too low. That precaution sounds odd, but the feedback control circuit is designed for O/P caps with ESR and ESL in a certain range. Modern ultra-low impedance parts might cause stability problems. I would recommend Nichicon PJ or UCC LXV, if you can find them; or Nichicon PW or UCC LXZ as second choices.
          PeteS in CA
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • a_p3rson
            Apple Watch Charging Controller Schematics / Boardview - 820-02601
            by a_p3rson
            Hi there,
            I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
            You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
            This daughterboard uses an interesting...
            04-21-2025, 11:41 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
          • repair-it
            Need advice testing a samsung power supply board with scope
            by repair-it
            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
            07-12-2025, 11:00 AM
