Refurbishing an old nice ATNG
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    By looking at the label I thought that this thing was going to be junk. But it turned out to be a really well designed ATNG, made in March, 2004. The pictures pretty much speak for themselves. 10A bridge rectifier. Besides the primary, all Fuhjyyu caps. But here's the crazy thing, the only ones that tested bad were the ones on the 5VSB, 3.3V, and -5V rail filtering. Even the ones that look like they got toasted by that 5V minimum load resistor were okay (btw, 7.5Ω is way too low to be on the 5V rail) I will change that resistor out while working on it, to at least 50Ω. Switching out that 16A ultra fast on the 12V for that 30A schottky. Removing a lot of flux on the soldering side. Oiled the fan, it was really dry. Very silent though even at full speed! It only has a max speed of 1500RPM. For a 2004 power supply, this thing was very well built. Perfect input filter, good sized heatsinks, good silicon, nice transformers, the 5VSB one looks above average. Large output toroids, big PI filters. This somewhat looks like a Macron design. I'm almost done recapping it. What do you guys think?
    • 31084
    Re: Refurbishing an old nice ATNG
    WOW - i think that's the first ATX supply i'v ever seen that actually used a fuseholder!!
    heatsinks remind me of powerman btw.
    • CapSwapper
      • Feb 2014
      • 69
      Teapos on the primary and Fuh(k)you caps on the secondary. I'm surprised it never caught on fire. IMO 10 years is the maximum service life I give a psu then I toss it. Those junk caps were probably way out of spec for years which stresses other components
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        wow, that's a very nice looking power supply.
        I bet it can do 400 watt continuous in spec.
        what primary switching transistors it uses?
        edit, just saw it in the pics, 13009. 400 watt would be the limit then.
        • Behemot
          • 4845
          • CZ
          OFC +5 V heavy design, not sure if dropping the minimum load from 3,33 W to 0,5 W is good idea. In modern +12 V heavy system the +5 V rail will barely be loaded at all, leaving it heavily crossloaded with +5 V skyrocketing and +12 V dropping down the tube.
          • everell
            • Jan 2009
            • 1514
            Just find an old Pentium three mother board, use this power supply, load it with Linux, and it will do fine! Still lots of Pentium three mother boards on Ebay....cheap!
            Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
            • Behemot
              • 4845
              • CZ
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Really? They're pretty rare, but I've even seen one in a Deer made in 2002/3 (Allied model)
                Those old ones made by FSP? Definitely.
                Yeah no kidding, I never leave either of those cap brands anywhere (except on the voltage doubler after testing.)
                If an old PSU is good enough, it is worth recapping, even if it's over 10 years old. Plus, I have a soft spot for older stuff
                Yeah I think it could too. The fan moves a good amount of air.
                I changed out the 5V with 100Ω, changed the stock 10Ω on the 3.3V with 50Ω, and left the 275Ω on the 12V. And, after changing out that ultra fast on the 12V with the schottky, and the combination of changing the load resistors, it doesn't act that way. I loaded it up with one of my systems which is an Athlon 64 x2 3800+, x4 DDR2 modules, 9800GT, and single 7200RPM hdd, and the 12V and 5V were really high under idle, the 12V read 12.86V, 5V read 5.30V, 3.3V read 3.33V, 5VSB read 5.19V.
                I do have an old dual P3 system that could use a PSU. But it could go into a 12V system as well, if I change the load resistors. I might even try just adding some 5V to this one to see what it does to the voltages.
                • Behemot
                  • 4845
                  • CZ
                  The voltages are out of spec, I would not use that thing. On +5 V heavy system the +12 V rail will go high over 13 V, making the compensation go crazy. It may even cease to work.
                  • прямо
                    Viper22A 5VSB circuit
                    by прямо
                    So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                    In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                    01-13-2024, 07:05 PM
                  • kotel studios
                    FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                    by kotel studios
                    Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                    Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                    I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                    Any ideas where to go next?
                    02-23-2025, 11:47 AM
                  • mrcliem
                    CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                    by mrcliem
                    Hello...
                    I got my self a dead CM V700 PSU, with nothing on +5vsb
                    I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                    As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                    The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                    I have read the datasheet and and still can not...
                    06-29-2023, 08:18 AM
                  • socketa
                    Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
                    by socketa
                    Rescued this one
                    Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
                    Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
                    The 5VSB drops to 2.5V when it 'shuts down'
                    And the voltage across the primary cap falls from 335V to 330V at the same moment
                    I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
                    12-20-2022, 03:06 AM
                  • hobostove
                    Corsair RM1000e - Help identify 5VSB Zener diode
                    by hobostove
                    Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                    Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                    There's a 22ohm resistor that's melted and open, but it still has the bands.
                    The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                    It looks like the diode connects the source and drain of a TNY284...
                    03-27-2025, 02:25 PM
