Re: After replacing bad capacitors, still nothing
I realised after stating that the PS tester measured only no load voltages that it is possible to load test each supply voltage with low duty cycle switching. That is if each voltage is loaded for 100mS over a cycle period of five seconds and the total load 100mS load is 300 watts then the average wattage is only 6 watts. I wonder if a low cost device is that sophisticated to do the switching this way and apply different loadings eg a heavy load on 5 volts and a light load on 5 Vsb. The data available on the PS-224 is not revealing.
Has somebody got some experience with this tester?
. But in the meantime I have 4 Capacitors that need immediate replacing each rated at 16V 3300uf and 105deg. I saw a break down review You Tube video where the host suggested that the 35V Capacitors were a better choice for manufacturers to use. Another video suggested that replacing capacitors of higher Voltage is fine but that the 3300uf rating should be kept the same. Can someone please clarify what the functional benefits...
