Dell Dimension PSU...
  • wan901
    • Jun 2007
    • 69
    Hello guys i like to ask a favor if anyone can help this type of DELL PSU...the originall was already cannot be use...so i like to convert from Normal ATX PSU to the Dell PSU ....do anyone have been done this before ?? DELL PSU 24 + 16pin
    P1
    Pin Function Pin Function
    1 +5 VDC (red) 13 PSON#2 (gray)
    2 Common (black) 14 Common (black)
    3 +5 VDC (red) 15 Common (black)
    4 Common (black) 16 Common (black)
    5 PWRGOOD (orange) 17 N/C
    6 +5 VFP (purple) 18 +5 VDC (red)
    7 +12 VDC (yellow) 19 +5 VDC (red)
    8 –12 VDC (blue) 20 +5 VDC (red)
    9 Common (black) 21 TFSC (brown)
    10 Common (black) 22 +5 VDC (red)
    11 +3.3 VDC (blue/white) 23 +3.3 VDC (blue/white)
    12 +3.3 VDC (blue/white) 24 Common (black)
    P2
    1 +3.3 VDC (blue/white) 9 +5 V (red)
    2 Common (black) 10 Common (black)
    3 +12 V (yellow) 11 N/C
    4 N/C 12 N/C 12 N/C
    5 N/C 13 N/C 13 N/C
    6 N/C 14 +5 V (red) 14 N/C
    7 +12 V (yellow) 15 Common (black)
    8 Common (black) 16 N/C
    have this information from http://pinouts.ru/Power/dell_dimension_psu_pinout.shtml
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Re: Dell Dimension PSU...
    I don't have an answer for you on the pinout, but if done right it will work fine for you. I now run a Generic PSU on a Dell GX 180. My Dell Mobo uses the standard ATX pinout so most any PSU works for me. You should PM some of the real Tech people on the forum for your answers on this issue. I don't want to see you end up doing it wrong, and turning your PC into magic smoke!
    Mark Twain
    John Paul Jones
    Rod Serling
    • starfury1
      • May 2006
      • 1256
      Humm you maybe able to get(or make) a converter lead not sure...I look into this while back.
      I think the only thing Dell did was rearrange what went where.
      (which if you plug the wrongly wired psu in it goes BOOM for you)
      So you have to compare it to a standard wire diagram for and AT ATX (whichever)
      Apple did a similar thing BUT on one of theirs, there is a different Voltage
      (non standard) on a pin...So you got to be real careful with apple look alike atx psu's
      So beware Apple and some Dells
      some links on a quick search ...I know there was a site that went through this and the links are somewhere on these forums...(just couldn't find it now)
      http://www.endpcnoise.com/cgi-bin/e/...=dellconverter
      http://www.athenapower.com/power_converter_list.htm
      If you know the pin out and are feeling really adventurous
      I suppose you could rewire a psu to be one.
      heres a 20 pin comparison, he is converting a Dell to atx...you want to go the other way
      http://www.speedystuff.com/stuff/dellps.html
      Just make sure of what you got and how you are going to do it...a wrong wire somewhere will probably let the magic smoke out!
      What the reall reasons are behind this I dont know but my guess is to keep it in house so you have to go back to them for a replacement (at 3 times the price)
      search the net and these forums...I know I have posted the link on that how to make the cable.
      HTH Cheers
      • wan901
        • Jun 2007
        • 69
        ThX VeRy MuCh GuyS .... ^_^
        • HTR-Informatique
          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
          by HTR-Informatique
          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
          I also changed the screen because the PC fell and the screen was broken.
          I changed the battery with a new and original battery.
          I also had corrosion/oxidation on the...
          02-09-2025, 06:51 AM
        • thinkcentre
          Dell Optiplex 3060 Micro USFF (IPCFL-CG Motherboard) - No LED / Short Circuit
          by thinkcentre
          this is my first post at Badcaps and in general i am new to fixing electronics. I am looking forward to learn a bit more about diagnosing and repairing :-)
          What I have around is a DELL OPTIPLEX 3060 Micro (USFF), which is not powering on, even not showing any signs of life (No amber / white LED).
          I got a original 65W DELL PSU / Power brick (PA-12 / 074VT4) which hopefull should be the correct one. I could get another DELL PSU with the Partnumber 0G6J41 with the same 4.9mm DC Jack connector as the one I already have, but I dont think that would help (maybe...
          11-09-2025, 12:39 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • The_Memory_Guy
          Dell Latitude 5520 refusing Bios Update, Black screen no matter what I do
          by The_Memory_Guy
          Hi, if this needs to go in different category please let me know
          I have Dell Latitude 5520, however it refusing a Bios Update, the current Bios version 1.30. Its 11th gen with with an 1135 G7 CPU.
          I have tried everything under the sun to try and get this Laptop to update the Bios, Latest version 1.47, however It wont do the Bios Update, via Windows, Via USB, Via Network, same issue, in Windows it does the checks and says its restarting the laptop, however all I get is black screen, nothing after that, 15/20/30 minutes, even 1 hour after.
          I tried using the...
          Today, 12:16 PM
        • Swedishpower
          Dell G3 15 3500 black screen
          by Swedishpower
          Hello
          I have search everywhere for a solution for my problem, but cant find it anywhere.
          When I was away to trow some garbage i always look in the electronic bin.
          and this time i find a laptop.
          Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
          the lamp for charmig is white.
          Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
          but no Dell logo.
          I tryed with a hdmi cable to another screen, still black.
          I started to search solution and tryed...
          07-06-2025, 06:18 AM
