Only stand by voltage
  • Josephmichael09
    • Oct 2014
    • 8
    Lc-42sv49u has stand by voltage and that's all
    When plugged in the stand by led turns on. When I try to power on the tv, the led turns off and remains off. Nothing happens.
    From the power supply there are 3 connectors. Two go to the main board and the other to the power inverter.
    I was takin measurements from one of the connectors the go to the main board. The colors on the connector are black, red, orange, brown, yellow, and green.
    With the power cord connected the only voltage u get is 5.2v coming from the orange pin(which I believe to be stand by voltage). There is still no voltage at the other pins and the stand by voltage does not drop to zero.
    The caps look ok. I am going to change them either way... I could use some direction. I am an amateur looking for experienced advice
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Only stand by voltage
    Better to ask about the tv in https://www.badcaps.net/forum/forumdisplay.php?f=31
    • DXseekerMO
      Vizio E400i-B2 missing stand-by voltage
      by DXseekerMO
      I picked up this Vizio E400i-B2 with no stand-by light and diagnosed it with missing stand-by voltage. I found a Power Supply at ShopJimmy, installed it but it didn't work properly. SJ refunded the transaction and did not ask me to send the board back.
      So I took some voltage readings upon the original board. Here's what I found:
      Main caps have 169.9v
      AC detect voltage is 1.3v
      None of the MOSFETS appear to be short.
      The opto (IC106) that appears to have something to do with stand-by voltage has 3.0 volts on terminal 1...
      10-30-2021, 10:19 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Fernon@Repair
      Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
      by Fernon@Repair
      i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
      VCCIO voltage ok
      VCCSA Voltage OK
      VCCPLL Voltage OK
      Ram Voltage ok
      RamVTT OK
      VPP 2.5 OK
      But No Core Voltage
      and i want to this vrm ic datasheet or pinout (ISL69269)
      anyone have this ic pinout voltages?...
      06-25-2025, 07:19 AM
      Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
      I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
      The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
      Now...
      06-09-2024, 10:57 AM
    • electron_jj
      Panasonic TH-L42D25A checking the PSU output voltage
      by electron_jj
      Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
      I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
      08-29-2021, 08:13 AM
