U.S.ROBOTICS 1000 SWITCH Mod USR7930
  • LEMO
    • Feb 2014
    • 9
    • Kaernten
    Delta Electronics ADP-30JP Powersupply ADP-30JP used in Netgear FS308
    After Powerdown no OUT voltage
    Found def CAP 47uF 25V has 4,8uF ESR =>20.0ohm
    Helpful was:
    https://groups.google.com/forum/#!to...-y/q7Zg4eESXEE
    A very common failure mode in SMPS's is an electrolytic cap in the startup circuit, causing the PSU
    to fail to restart after a power interruption. This is often mis-attributed to mains problems/spikes
    etc. as the fault only exhibits after a switch-off, when it then fails to re-start - the problem may
    actually have been there unnoticed for years if it has never been switched off.
    Look for a small, low-voltage (<=63V) electrolytic on the mains side of the supply - there will
    typically only be one, and replace it ( ensure the replacement has a 105 deg.C temp rating).
    And be careful - the main HV reservoir cap on a non-starting PSU can really hurt for many minutes
    after disconnecting from mains...!
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: U.S.ROBOTICS 1000 SWITCH Mod USR7930
    Yeah a lot of money on this raised
      Very common startup cap failure for the Vcc of the SMPS IC. If you heat up the cap with hair dryer, you will see the ESR goes down if the cap is not too far gone.
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • Natob82
        Micro Momentary Push Switch?
        by Natob82
        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
        12-21-2022, 05:22 AM
      • grimacelord
        NEC TurboExpress On/Off Power Switch Replacement Help
        by grimacelord
        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
        11-09-2023, 09:49 AM
      • SluggerB
        Help making a switch work the opposite way with a relay
        by SluggerB
        I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
        I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
        It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
        02-07-2025, 07:57 PM
        Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 1000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H Hybrid (2-in-1) Studio Specification for Upgrade or Repair
        This specification for the Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 1000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio, 14.4", 1000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H boardview and Microsoft Surface Laptop Studio, 14.4", 1000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H schematic. Our users have donated over 1 million documents...
        09-07-2024, 04:10 AM
