Need help with Smart-UPS 1250 fuse
  • Maxxarcade
    • Jul 2006
    • 973
    I am replacing the batteries in a Smart-UPS 1250 that has been sitting for years. The last one I did had a different style fuse that was smaller, but the other ones I have use this odd circuit board with two 50 amp fuses.
    I can't get it to fit no matter what I do. There is no clearance above or in front of the batteries. Am I missing some angle brackets or something? Anyone have pics of one of these assembled? It's driving me crazy, I tested it with a temporary jumper and everything works fine, but I can't put it together without the fuse in place
  • Maxxarcade
    • Jul 2006
    • 973
    Re: Need help with Smart-UPS 1250 fuse
    Got it to work by stacking two sets of the black spacers and using longer screws, And mounting it in front of the batteries with the fuses closest to the bottom. It barely fit, so I put a protective sheet of plastic over it in case the front panel circuit board may end up touching it.
    When I first tested it out, it went to low battery mode right away. I let it charge till the fan stopped, and it ran a 500W load in low battery alarm for over 20 minutes before it actually shut off. Hopefully it will recalibrate itself and work properly after the next charge.
    The batteries are cheap ones from China (Universal Battery) but still seem to pack a punch. Let's see if they outlast the ones from Vietnam that are in all my other UPS units
    The best part is that the seller sent me the wrong pair of batteries at first, but told me to keep them and then sent the proper ones. Then I found someone on Ebay who sold me a pair of Back-UPS 600's for $35 shipped, and I put the new batteries in them. So I ended up with a Smart-UPS 1250 and a pair of Back-UPS 600's with new batteries for less than $100 total
    I still have 3 more Smart-UPS 1250's left in the pile, which will get new batteries when I can afford it. I picked all but one of my UPS's out of the trash, and they are running great with new batteries now I love good free stuff.
    • japlytic
      • Oct 2005
      • 2086
      For UPS units with batteries in series: be sure to charge the batteries evenly - each battery must have a voltage range of 0.1V after a 6 hour rest after being fully charged with the charger disconnected (e.g. battery A is 12.82V and battery B is 12.78V, which gives a range of 0.04V)
      Also, have you got a picture of the fuse board successfully fitted with longer screws?
      • Maxxarcade
        • Jul 2006
        • 973
        Regretfully, I don't have an assembled pic. I was too pressed to get it together and installed in the server rack.
        Hopefully the batteries will be ok, since they were bought as a kit. I had read somewhere that the batteries will be evenly charged after doing two complete charge/discharge cycles with the UPS, which also calibrated the battery meter.
        I'm a bit worried about the quality of the batteries though, since I had a small UPS with a single 12v 7ah battery by the same company, and it lasted less than two years. Maybe the more advanced charging circuits in the Smart-UPS, and the fact that these batteries are bigger, will make these last longer.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          those small ups units are very hard on that tiny 7ah battery.
          i have seen 50+amp discharge rates on an apc back ups 650
          any degradation at all and they drop below the low voltage shutoff as soon as the inverter turns on with a load.cheap crap batteries are even worse.
          btw those universal brand batts dont hold up in wheelchairs very long.
          those vietnam batts from gruber dont either.
          if you have a mk or east penn/deka dealer nearby spend a few more $.
          • carrzkiss
            Cyberpower cps1500avr not charging batteries
            by carrzkiss
            Hello, all.
            Cyberpower Battery Backup Unit.
            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
            Checking the voltage, it was down to 22v.
            I quickly removed everything...
            06-15-2024, 02:10 PM
          • corrize
            A funny fuse story – Lumix LX100 II
            by corrize
            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
            10-19-2023, 09:58 AM
            MSI Gaming Pulse GL66 11UCK-1250 Notebook GL Specification for Upgrade or Repair
            This specification for the MSI Gaming Pulse GL66 11UCK-1250 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pulse GL66 11UCK-1250 boardview and Pulse GL66 11UCK-1250 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-07-2024, 06:11 AM
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
          • howardc64
            Where do repair shops buy MB replacement batteries?
            by howardc64
            Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
            Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
            BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
            07-25-2024, 10:42 AM
