Breakdown of a skimpy CyberLink CWT-320ATX 320W PSU (warning: inline images)
  • everell
    • Jan 2009
    • 1514
    Re: Breakdown of a skimpy CyberLink CWT-320ATX 320W PSU (warning: inline images)
    Try drawing the 5vsb in the Bestec ATX-250 12E and see if you can determine the reason so many failed!
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • Nagy Daniel
      Lowest possible resistance on laptop motherboard rail - Guide Table request
      by Nagy Daniel
      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
      So, I generated a table with AI so I can...
      03-04-2025, 08:24 AM
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
    • lefetylorant
      Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
      by lefetylorant
      Hello Everyone,
      Long story short, I got this unit for very cheap.
      I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
      I've performed some measurements:
      - 20V rail perfectly...
      09-14-2023, 05:05 AM
    • bimole
      Weird behavior on 3.3V rail of a CORSAIR CX600
      by bimole
      A colleague gave me an apparently ill CORSAIR CX600.
      He told me that he heard a banging noise, and smelt the magic smoke.
      After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
      I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
      It's another story on the 3.3V rail...
      I have some devices to test deeply PSUs (scope, AC source, electronic load)...
      02-13-2025, 04:49 AM
      KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
      by momaka
      For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
      http://www.rmac.kingwin.com/products.../abt_650MM.asp
      I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
      What mostly drew me into buying it is its 2x PCI-E power connectors...
      03-29-2022, 11:34 PM
