Datron/Siemaks M600VD3 UPS bad charger 400V cap
  • japlytic
    • Oct 2005
    • 2086
    A few weeks ago, I bought a Datron/Siemaks M600VD3 online double conversion UPS from a local junkyard. The only problem was that the 400V 68uF 105C Marcon AUF series unit in the power supply have bulged after 13 years of use, causing the charger to not charge the batteries (which still retained a charge after recharging).
    Replacing this capacitor made the unit work again.
    13 years is quite a reasonable life for such a capacitor... and the unit had extensive protection logic inside it.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Datron/Siemaks M600VD3 UPS bad charger 400V cap
    No nude pics?
    • motormayhem
      Lenovo T460 Only Charges on One Charger
      by motormayhem
      Laptop Question
      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
      05-12-2023, 01:46 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • flat-earther
      ASUS X54H laptop thinks it's always charging even with charger unplugged
      by flat-earther
      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
      Windows also shows ''Plugged in'' when charger is not connected.
      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
      If I let battery run out and say it has 3% Windows will...
      06-24-2025, 09:32 AM
    • Johndill
      Dell Inspiron 7567 LA-D993P odd charger issue
      by Johndill
      Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
      There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
      I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
      Here are the tested scenarios:
      1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
      2. With the laptop off, plug in charger (LED says on) & the front charging...
      11-16-2022, 10:55 PM
