ocz 420 u12 swollen caps
  • Behemot
    • 4845
    • CZ
    #61
    Re: ocz 420 u12 swollen caps
    • predator0357
      • Jul 2014
      • 159
      • Israel
      #62
      Originally posted by Behemot
      I posted pic of the bad caps and i am just wanted some replay on them just for fun :-)
      • Behemot
        • 4845
        • CZ
        #63
        Seen worse, especially the small ones. Recordman is some with aprox. 150 ohm ESR. Or the next one which did not have any capacitance, any ESR, it was probably burned inside
        • c_hegge
          • Sep 2009
          • 5219
          That one that read only 27pF was bad. It might still make a good replacement for a ceramic cap, though
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
            by momaka
            03-15-2023, 10:17 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
