Dell Laptop Power Jack Repair
  • Paul S
    • Sep 2006
    • 326
    I have a Dell Inspiron 1150, about 3 years old. I recently started having random freeze-ups on it, along with some video distortion. It does this in both Linux and Windows. Only a hard shutdown will do anything.
    I dismantled it, kind of hoping to find some bad capacitors. There is only one can type capacitor, and it looks OK.
    As long as I have it apart, I am going to fix the power jack on it. The only problem is the replacement jacks available all look slightly different than the original. A section on the back, that connect the two pins, is missing.
    The pics show the original, with a solder repair that I made, and the replacement.
    Anyone know if this is an OK replacement?
    (Sorry for the fuzzy pics, I still didn't buy a camera and used a webcam.)
  • linuxguru
    • Apr 2005
    • 1564
    Re: Dell Laptop Power Jack Repair
    Just check the continuity across those two pins on the replacement jack. If it's shorted internally, you're OK. Otherwise just solder it in and bridge those two pins with a short length of thick wire/lead.
    The freeze-ups are most probably due to dust in the HSF assembly. Remove the HSF, clean out the entire air-flow path, remove the white goop between the CPU and the HSF with isopropyl alcohol, and apply Arctic Silver III, V or Ceramique instead. It will drop your CPU temperature by about 3-5 degrees and help avoid the freezes.
    • Paul S
      • Sep 2006
      • 326
      I was expecting it to be pretty dirty, but it wasn't very bad. I opened it up and cleaned it out about a year ago.
      I also was planning on doing exactly what you said about the HSF. I guess great minds think alike!
      I haven't purchased the new jack yet. I wanted to see if I could find an exact match. I did find a supplier that says that this is a new and improved jack:
      http://doctorlaptop-repair-jack.com/...products_id=42
      Thanks for the reply,
      Paul
      • YOUCEF4787
        Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
        by YOUCEF4787
        I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
        Initial Problem:
        The laptop was completely dead, no signs of life, no power LED.
        Action Taken:
        I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
        Current Situation & The Main Issue:
        The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
        09-21-2025, 12:19 PM
      • capoplays
        Help with BIOS update on Dell G15 5515 after chip replacement
        by capoplays
        Hey everyone,
        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
        When I check the BIOS using the F12 menu Flash...
        10-24-2025, 06:53 AM
      • diamon
        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
        by diamon
        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
        Pictures of these boards:
        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
        Dell...
        02-28-2024, 12:51 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • diamon
        Dell 5590 LA-F412P does charge with USB-C not with DC-Jack
        by diamon
        As mentioned, I have a Dell 5590 laptop with motherboard LA-F412P.
        This laptop works with the USB-C charger and not with DC-Jack charger.
        With the USB-C charger attached, the battery is charging and in the BIOS the charger is also recognized.
        With the DC-Jack charger attached (USB-C charger removed), the light of the charger is not going off and the BIOS does not see the charger (message AC Adapter = Not installed). I'm using original Dell chargers and I have tested the used chargers on other Dell laptops and they are working correctly.
        I have replaced the DC-Jack,...
        12-29-2023, 07:29 AM
