Unfamiliar Zener Diode
  • pbinet
    pbinet
    • Nov 2024
    • 10
    I am a hobbyist electronics repairer and am working on a number of projects including a DVD player consumer SMPS 110V and I'm stuck with one component I can't identify that reads short. On the board it is identified as a zener diode and it connects in reverse between the control pin of the chip MIP2E4D and the secondary winding. The component length is 2.3mm. I have attached a photo and would appreciate any help
  • harp
    • Jun 2022
    • 592
    • Planet Earth
    Green green mean 55, maybe 5.5V? Aplication circuit maybe help...
    • R_J
      • 9523
      Is the zener connected between Hot ground (S of ic) and (C of ic)? It is likely a 15v zener diode (panasonic MAZ4150) Is this power supply in a Sony dvd by chance?
      Looks like the Control pin voltage is, Min 5.7v, Max 6.6v Typ 6.2v
      The Blue on the lead is the Vz rating, brown first band, green second band, green third band
      • pbinet
        pbinet
        • Nov 2024
        • 10
        Thanks RJ. It is a Sony DVD and that is the circuit. Can I use a standard 15V zener or do I have to source the MAZ4150?
        Peter
        • R_J
          • 9523
          I would just use a standard 1 watt zener, it seems to be more for spike protection than anything, I would also replace the two electrolytics in that circuit.
          • pbinet
            pbinet
            • Nov 2024
            • 10
            Thanks RJ. Both caps read OK with reasonable ESR but I'll change them as you suggest.
            Peter
              • 30941
              did you check the diode off the board?
              • pbinet
                pbinet
                • Nov 2024
                • 10
                Thanks to all! My first time posting in this forum and I am well impressed with all the responses. Thank you all. I have followed RJ's advice and the high voltage supply is working. There are ten low voltage supplies four of which read differently than posted on the board so I will now work on tracing/replacing the components in those lines.
                Regards,
                Peter
                • R_J
                  • 9523
                  The markings printed on the board may be wrong for this model dvd, the power supply is made by mitsumi for many different products, maybe it is time to post the model number of the dvd player or look online for a service manual.
                  Does the dvd player work? which voltages are wrong? some of the voltages are switched and only present when the player is on.
                  • pbinet
                    pbinet
                    • Nov 2024
                    • 10
                    R J Yes I should have posted the model number it is Sony DVD player model NC875V. I now have the service manual with schematic from ElectroTanya. The low voltages are on pin 1 reads 5.45V should be 8V, pin 5 reads 3.5V should be 5V, pin 5 reads 3.0V should be 3.3V, and pin 6 reads 3.5V should read 5V. Two components on the board I don't recognise are green smd capacitor looking components which the schematic marks as P311 and P312. One of them P311 doesn't read and no voltage is flowing from it into the two diodes D315 and D317 in series.
                    • pbinet
                      pbinet
                      • Nov 2024
                      • 10
                      Apologies as I noticed I uploaded the full manual instead of just the power block schematic. I have now attached the schematic and a photo of the component P312. I have already removed P311 from the board. Two issues with these components in the circuit are P311 blocked all voltage and P312 drops 1.5 volts. The block diagram elsewhere in the manual shows these as connectors. I don't know if there is something special about these components or if I could just replace them with zero ohm resistors?
                      • R_J
                        • 9523
                        They appear to be smd fuses (different sony model) are there any letters on them?
                        • pbinet
                          pbinet
                          • Nov 2024
                          • 10
                          Yes the letter Z (photo attached). I did temporarily put in zero ohm resistors just to check and now have all working voltages.
                          • R_J
                            • 9523
                            Looks like N which would be 2 amp likely 32v. Good to hear it is working.
                            • pbinet
                              pbinet
                              • Nov 2024
                              • 10
                              Thanks RJ. I'll source those and finish the job when they arrive. I really appreciate your help.
                              Peter
                              • unimatrix93
                                TV backlight zener diode
                                by unimatrix93
                                Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                The led strips has 9 6V leds.
                                02-10-2025, 12:13 PM
                                NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                by sam_sam_sam
                                I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                I bought this from an eBay seller but unfortunately they only had one
                                I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                I bought three of from them to also make battery packs with this output power limit in mind
                                I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                04-23-2025, 05:50 AM
                              • nev1001
                                What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                by nev1001
                                Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                I think an issue could be a zener diode (or capacitor) which has shorted out.
                                The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                04-17-2025, 05:09 PM
                              • Vincenzo2
                                Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                                by Vincenzo2
                                My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                                Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                                I put some pictures here to show that it is labeled "M7"....
                                09-07-2023, 07:43 PM
                              • hobostove
                                Corsair RM1000e - Help identify 5VSB Zener diode
                                by hobostove
                                Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                There's a 22ohm resistor that's melted and open, but it still has the bands.
                                The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                It looks like the diode connects the source and drain of a TNY284...
                                03-27-2025, 02:25 PM
