3 power supplies from the past
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    #41
    Re: 3 power supplies from the past
    The TNRs in the photos are in the feedback circuit and those are not stressed or heated, so I left them.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      #42
      Good save!
      The 5VSB circuit looks interesting as I see Q1 has 4 pins instead of the regular 3. Perhaps a dual transistor of some sort? I wonder if it is a 2-transistor design or perhaps Q1 is actually an IC (like a TOPswitch or something similar).
      The only thing I would do extra is take a flat screwdriver and open the gaps between the heatsink fins. This should help with the heat dissipation a bit. But overall, it looks like a well-built PSU, so it may not need this mod.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        #43
        Originally posted by momaka
        Good save!
        Originally posted by goodpsusearch
        This psu doesn't have the typical 2 transistor circuit, as it uses a Fairchild 1H0265R Power Switch(FPS). I don't know if that means 5vsb is safe from failing or overvolting, but it's interesting to see that very old psus went a level higher from CWT motherboard killer Antec psus.
        The fan is in series with the thermistor, so it rotates fast enough to keep the psu cool.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          #44
          ^ Ah okay. Probably pretty safe from over-voltage then.
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            #45
            I modded and recapped the Enhance power supply.
            Wester547 was right about the ADDA fan. It was completely dry and noisy! I oiled it using singer sewing machine oil.
            The fan speed controller circuit is designed to keep the psu cool. This power supply is not by any means silent. Even when completely cold the fan moves a reasonable amount of air.
            Another thing that I liked is that this unit's protections are fairly tight. With no load connected the 12V line settles at 10.7V, and the psu shuts down immediately. This does not happen with Linkworld psus or Macron. I have crossloaded them to the point that the voltages went clearly out of specs without shutting down.
            I replaced the BYQ30E-200 ultra fast rectifier, rated for 16A with STPS20H100CT.
            5vsb: 2x470uF 16V Jamicon WG --> 2x1000uF 6.3V Sanyo CG
            -12V: 1x470uF 16V Jamicon WG --> not changed
            -5V: 22uF 16v Teapo SEK --> 100uF 16V Teapo SEK
            3.3V: 1x 2200uF 6.3V Teapo SC & 1x 1000uF 6.3V Jamicon WG --> 2x 2200uF 6.3V Teapo SC & SX
            5V: 2x 2200uF 6.3V Teapo SC --> 1x 2200uF 6.3V Teapo SC & 1x2200uF 16V Nichicon PL
            12V: 1x 3300uF 16V Jamicon WG --> not changed
            I removed the glue from everyplace and used Arctic Silver Thermal Adhesive to permamently attach the thermistor to secondary heatsink.
            It works and the voltages are stable with 12V computer.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #46
              Wow, that's a nice Deer there (giveaway: "RD-DW" on transformers). Good save!
              Just make sure it doesn't have any secondary output loading resistors that have very low resistance. Deer typically likes to put 10 Ohms on the 3.3V rail, 47 Ohms on the 5V rail, and 100 Ohms on the 12V rail - all a terrible choice IMO.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                #47
                Actually, I don't think it's possible that Deer made it. The supervisor IC is Enhance proprietary. So, the OEM should be Enhance.
                • japlytic
                  • Oct 2005
                  • 2086
                  Unfortunately, this psu lacks an ATX 12V connector.
                  What do you think?
                  The ATX12V specification was not introduced in ATX power supplies until a few years later.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    #49
                    IIRC, Enhance did used to sell some units that were made by Deer/Allied, and I think I saw that somewhere in the pictorial thread (was a very very long time ago though, so my memory could have been degraded).
                    And yeah, you are right - it looks nothing like the typical Deer. Perhaps Deer built these specially for Enhance. Or perhaps Enhance bought transformers from Deer? I don't know, but those "RD-DW" markings I've seen only on Deer PSUs.
                    • прямо
                      Viper22A 5VSB circuit
                      by прямо
                      So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                      In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                      01-13-2024, 07:05 PM
                    • kotel studios
                      FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                      by kotel studios
                      Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                      Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                      I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                      Any ideas where to go next?
                      02-23-2025, 11:47 AM
                    • iMic
                      Vintage AT Power Supplies - Selecting Capacitors
                      by iMic
                      Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                      The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                      02-19-2023, 06:45 PM
                    • triplefour
                      by triplefour
                      09-13-2023, 10:43 PM
                    • socketa
                      Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
                      by socketa
                      Rescued this one
                      Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
                      Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
                      The 5VSB drops to 2.5V when it 'shuts down'
                      And the voltage across the primary cap falls from 335V to 330V at the same moment
                      I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
                      12-20-2022, 03:06 AM
