HP laptop supply cable replacement
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    I have here a working HP laptop power supply with a busted cable. I'd like to replace the cable but the original cable has 3 wires while the replacement cable has only two. Can I leave one not connected?
    Cheers
    • 31063
    Re: HP laptop supply cable replacement
    foto of the plug?
    • Agent24
      I see dead caps
      • Oct 2007
      • 4963
      • New Zealand
      Need more details, photo, model number etc
      -David VanHorn
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        power supply cable? or what?
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
        • r2digital
          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
          by r2digital
          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
          04-18-2024, 03:50 PM
        • fweonea
          HP-Pavilion x360 Laptop Dead After USB-C Cable Connection
          by fweonea
          While at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
          I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...
          01-16-2024, 11:35 AM
          03-31-2024, 02:12 PM
