Time to rework my Antec SL350! >_<
  • Logistics
    • Apr 2007
    • 721
    Re: Time to rework my Antec SL350! &gt;_&lt;
    Yes, 999999999, that cap. I wasn't sure if Krankshaft was replying to my post or just telling a story, because I defenitely wasn't talking about the gigantic film cap across the mains.
    There IS a stripe on the cap in that picture. At the time, I didn't know which one was supposed to be bipolar so after consulting with the other users I decided to just put a polarized there for the time being. It's all been running fine, although I have now and again gotten random resets. If it happens again, I'll let you know. It's either because of that cap which was polarized, until now OR it's because the OST's on my P4PE are starting to go. I don't know what sort of a load my system is for my old SL350. This is my system:
    P4 2GHz
    Asus P4PE
    2 x 512MB PC2100
    GeForce FX 5600 Ultra (has it's own molex)
    1HDD
    1DVD-ROM
    And these days, I'm using the onboard LAN and Audio. I don't imagine this is a huge drain on my SL350, but what's your opinion?
    p.s. How did you make such a nice looking arrow?
    • 999999999
      • Sep 2006
      • 774
      Does it only reset in windows or if it's sitting in the bios menus? Just trying to rule out software, I doubt that cap is the problem but comparison to other SL350 should help, or trace the circuit and measure it. You need a multimeter.
      P4 2GHz
      Asus P4PE
      2 x 512MB PC2100
      1HDD
      1DVD-ROM
      SL350 is something like 35A/5V and 16A/12V, a bit of a mismatch since your system uses more 12V current than was intended by the SL350 design. With a multimeter you might measure what happens when the 12V load is high. I don't recall on the FX5600 if that was in the early days of nVidia using more 5V current or not, now video cards use more 12V but I had a FX5900 which did use a few amps @ 5V, IIRC.
      Obviously something has to give, if this mobo-PSU combo keeps resetting and you can't track it down with a multimeter then you'll need to try running the system with another PSU.
      Paint Shop Pro, it looked better before I JPEGed it down to a bandwidth friendly size.
      • titomno2
        Gaming Laptop Zephyrus S17 TFT not detected every time !
        by titomno2
        Hi guys,
        I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
        So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
        On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
        Then the screen won't work for a long period of time.
        If I wait 1 or 2 hours it work again most of the time.
        When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
        01-19-2025, 08:27 AM
      • flat-earther
        Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
        by flat-earther
        I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
        To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
        I have opened the camera and I think there is enough room to add something inside to accomplish this:
        The camera is powered by a 3.7V nominal single cell lithium ion battery.
        So I need to connect another battery in...
        06-08-2025, 02:00 AM
      • piernov
        Core 2 "gaming" build with SLI
        by piernov
        My turn to post a build I guess, wasted way too much time on this one…
        First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
        Everything done with random parts I had lying around.
        Specs :
        • CPU: Core 2 Quad Q9450
        • RAM: 2x2GB KHX6400D2K2
        • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
        • MB: P5N-E SLI
        • PSU: Antec Basiq Power 550 Plus
        • HDD: Hitachi Ultrastar A7K2000 1TB
        • ODDs: DVD ROM, DVD RW
        • Case: not sure
        Cooling:
        • 92mm rear fan
        • 120mm front fan
        • Additional heatsink on southbridge
        05-20-2023, 11:38 AM
      • OscarAV
        HP Pavilion dm4-1065dx long time to get the power led on
        by OscarAV
        I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
        I have made a quick search for my laptop but I have not seen anything similar.
        I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
        09-23-2024, 05:53 PM
      • BigOof
        Pioneer RM-07 Active monitors cutting out from time to time
        by BigOof
        I have a pair of Pioneer RM-07 monitors that I bought a while ago. When I was testing them I noticed that one speaker would cut out and I thought it was just a bad cable connection. At the price they were being sold for I was willing to take a risk on them. However, 6 months later and the one monitor still has the same issue. Most of the time it works, but there are times that the power LED is on but I get absolutely no sound. I can hear the relay clicking on/off sometimes and then it will/won't work depending on what it feels like. I've tried XLR and RCA inputs with the same issue. There's no...
        12-18-2024, 04:35 AM
