Atoll ST200 Amp Power Supply Problem
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    Hi, A friend's streamer wend down after a lightening storm. It's dead.
    I'd like to get some pointers before I go at it as it's an expensive piece of kit.
    I already posted this in the audio section but got no replies. So hopefully somebody with PSU knowledge can help me here.
    I'm not familiar with the damage lightening can do so any pointers would be gratefully received.
    I've had a look at this. Both the 5VDC and 3.3VDC are sitting on about 2VDC.
    There's two 7805 regulators one has an output of 5VDC the other is very hot and has that 2VDC level on the output.
    I'd like to cut the output leg of the 7805 next to see if it's being pulled low, but I can't get in at it. So I'd have to strip out the unit and remove it from the PCB.
    My question is to ye experienced people, could the 7805 be blown or is it most likely being pulled low?
    And if so, by what, given that this unit suffered from a lightening strike?
    Thanks!​
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    more likely pulled low. 7805's rarely fail... do what you need to verify.
      • Jul 2011
      • 6060
      I would carefully remove all of the parts that hold down the circuit board and remove the two 7805 regulators or whatever provides the 3 volt rail and test them out of the circuit if it has a capacitor on the input or output side of the regulator use them as well to test the voltage of each regulator if they produce the 5 volts that they are supposed to then you need to find out what has shorted out the power supply rails and remove them from the circuit board and see if you still have a short
      I would be suspicious of any ohm reading less than 500 ohms as a short circuit
      One note if you are not familiar with the pin outs of 7805 look at the data sheet for this information and make sure that you hook it up correctly for testing it out of the circuit
      • habanerocat
        • Nov 2014
        • 96
        • Ireland
        Thanks for the input lads.
        In the meantime he has decided to send it back to the manufacturer.
        Probably wise as that 5VDC line was going absolutely everywhere.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
          07-01-2024, 06:34 AM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
