Sfx 380watt failed mod
  • bearjumpjump
    • Jul 2024
    • 13
    • Indonesia
    So I try to modify this cheapo sfx power supply
    I change it's
    - main cap configuration to parallel rubycon 150uf 450v two pair
    -diode bridge in one package form with heatsink
    - add input inductor, X & Y cap
    But it won't start anymore lol
    5v sb is Okey
    Sc1605 got all of its voltage
    I got 320dc on main cap
    I got 14dc on output of middle small transformer (d9 those 1n4148)
    Secondary diodes is good (two pair mbr1645, f1620)
    Primary trannies is good (two 13700b)
    Power management ic is me8117 i don't know if it's good lol
    Please help me guys
    I really appreciate it
    Thank you
  • bearjumpjump
    • Jul 2024
    • 13
    • Indonesia
    When power supply switch on
    Optopcoupler
    Pin 1 4.98v
    Pin 2 3.9v
    Pin 3 1.16v
    Pin 4 hot ground
    Ic power management
    Me8117
    Pin 1 no reading
    Pun 2 6.45v
    Pin 3 no reading (connected to pin3 Opto)
    Pin4 no reading (connected to pin4 Opto)
    Pin5 no reading
    Pin6 cut leg/no connection
    Pin7&8 1v (connected same winding on small transformer)
    The other end winding read 324v
    First npn13007
    B = no reading
    C = 325v
    E = no reading (connected to collector's second 13007)
    Second npn13007
    B= no reading
    C= no reading or fluctuate sometimes
    E= no reading
    Main big transformer 0v on all pin whatsoever
    12v pad after inductor reading 2v
    Other rails is 0volt lol
    I already change all of 1n4148 diodes
    • bearjumpjump
      • Jul 2024
      • 13
      • Indonesia
      • ahmedtou
        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
        by ahmedtou
        help me please
        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
        I will share all the details with you, including the disc information.
        Code:
        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
        Current Profile: BD-R
        Disc Information:
        Status: Empty
        State of Last Session: Empty
        Erasable: No
        Free Sectors: 12,219,392
        Free Space: 25,025,314,816 bytes
        Free Time: 2715:27:17 (MM:SS:FF)
        Next
        08-27-2025, 08:49 AM
      • dennis_elx33
        3PHASE STEP-DOWN Transformer in Check
        by dennis_elx33
        Hello All,
        i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
        Problem statement: Power tripped Off
        Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
        Action Done:
        1) Replaced the faulty parts with good spare.
        2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
        12-02-2024, 06:52 AM
      • karatzdi
        Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
        by karatzdi
        I know some might say... just buy another one. Sell it as parts..!
        So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
        Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
        Spent some time downloading the Service...
        06-11-2024, 08:38 AM
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • SuperAman
        PS5 HDMI port diode reading?
        by SuperAman
        I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
        02-03-2024, 10:16 PM
