fault in laptop charger 65 W lenovo usb c (adlx65ycc3d)
  • claws77
    • Apr 2024
    • 103
    • India
    the laptop charger does not work. not output voltage.
    removed 18V and GND cable from secondary, left ID cable-- suspecting short in output cord and then measurements were made.
    input cord is fine -- checked. 220 V AC
    primary transformer voltage (V_DE) is fine - checked 310.1 VDC
    secondary transformer voltage is 0V (V_AB) -dont know why
    C1 and C2 are electrolytic caps marked at 470uF but reads 987 uF -- seems connected in parallel. V_c1 =0V and V_c2 = 0V.
  • mon2
    • Dec 2019
    • 14577
    Hello.
    1) this may be a post that is better suited for posting in the power supply forum:
    Troubleshooting Power Supplies and Power Supply Design - Badcaps
    2) yes, if the caps are in parallel then the total capacity will be the sum of the 2 capacitors.
    3) Being a Type C power adapter, the power adapter should start with a default power value of 5 volts. Only after a proper communication over the CCx (single wire BMC signalling), the target / consumer side of the connector will request the list of power delivery (PD) contracts (voltage & current pairs). After receiving this list, the consumer will decide on the best PD contract that is useful to power its load. Often this is a 20V PD contract. You can source various PD bus analyzers to monitor this traffic using a host PC. Features will vary with the tool's cost.
    With no power to the adapter. You can review the DIODE mode measurements of each contact on the USB Type C connector. Red meter probe to GROUND. Black meter probe to the point to test. If you measure ~0 volts, then that pin is shorted.
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      From the picture, seems to me the charger is of a normal type, with resistor divider at the tip . Or are these usb-c chargers ( I have not worked with one of these yet ) like Apple chargers, with a pcb on the tip ?
      claws77, after cleaning more of that white glue, can you measure voltage at the main capacitor, and also identify the markings on the charger controller IC ?
      • claws77
        • Apr 2024
        • 103
        • India
        i do not know what you mean by main capacitor
        i can see 3 electrolytic capacitors(one big on input and 2 on output)
        input capacitor has 320 V
        output ones have 0V each.
        it is WT6633P. (a W is missing from image)
        and the primary controller chip, is LD5763GS i think
        • CapLeaker
          Leaking Member
          • 8296
          Probably the weltrend chip disabling the output. Check the fault pin for active low.
          • claws77
            • Apr 2024
            • 103
            • India
            LD57636S IC has a short.
            this black something(first from left) has a short too.
            removing the IC and the black thing the short goes away.
            • CapLeaker
              Leaking Member
              • 8296
              https://www.leadtrend.com.tw/images/...0122155721.pdf datasheet
              Check the mosfet and the gate drive too...
              • claws77
                • Apr 2024
                • 103
                • India
                which pin of LD576 pins are you talking about?
                or are you talking about on the PCB.
                there are mosfets on both primary (one) or secondary sides(two)
                primary side mosfet is short (in circuit measurement)
                but no short on secondary side
                • CapLeaker
                  Leaking Member
                  • 8296
                  You found the PWM shorted on the primary. Right now you don't know why it did that. Chances are very high, the MOSFET on the primary blew and thus took the PWM with it. If you don't check the gate drive circuit between the PWM and including the MOSFET, you may blow the PWM again since the MOSFET gate is shorted to its drain and source pins.
                  Ive seen a PWM just play dead, but that is very rare,
                  • claws77
                    • Apr 2024
                    • 103
                    • India
                    • CapLeaker
                      Leaking Member
                      • 8296
                      You have to figure out why VCC is shorted to GND. Is it the PWM or something else before that. This is your first problem to solve. After you figured this out you need to look at the gate drive and check if the MOSFET is shorted. That diode you circled should show on your DMM in diode mode open one way and a voltage drop of 0.5 the other way. If not replace it and check these resistors too.
                      off course this is just an example circuit and things are probably different on your PSU.
                        • 31161
                        did you clean all the rubber crap off the top?
                        these really compact designs are shit, when something fails it often arc's across to other parts!
                        you may get lucky, i had one where a 4wire choke on the topside had a burned leg on it from poor soldering - i just replaced it with a pair of jumpers.
                        • claws77
                          • Apr 2024
                          • 103
                          • India
                          stj, yes i cleaned all the white goo , checked primary mosfet (shorted), primary PWM ic short, gate drive diode is open.
                          did not find any such obvious shorts in secondary side.
                          since i do not have the necessary parts
                          i am thinking of using this board to understand and repair other SMPS
                          or if i get lucky with parts maybe repair this one
                          thankyou everyone
                          • motormayhem
                            Lenovo T460 Only Charges on One Charger
                            by motormayhem
                            Laptop Question
                            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                            05-12-2023, 01:46 PM
                          • coasterghost
                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                            by coasterghost
                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                            System Hardware:
                            Processor: AMD Ryzen 7 PRO 5850U
                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                            09-08-2025, 10:46 PM
                          • claws77
                            by claws77
                            this is a cross post.
                            the laptop charger does not work. no output voltage.
                            C1 and C2 are electrolytic caps marked at 470uF but reads 987 uF -- seems connected in parallel. V_c1 =0V and V_c2 = 0V....
                            06-15-2024, 06:46 AM
                          • Mita99
                            Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                            by Mita99
                            Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                            Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                            Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                            04-27-2025, 07:20 PM
                          • totto210
                            lenovo legion 5 15-lmh05 nm-c911 charger problems
                            by totto210
                            Hi guys, well the summary is this:
                            the equipment arrived because it did not turn on (it had been the original 230w source the problem) then I feed with my regulated source and without wanting to invert the poles. the equipment turned on and turned off.
                            This damaged the charger and its mosfets both high and low switching.
                            It also damaged the input mosfet (pq102).
                            by chance i had another lenovo legion just like this one and i removed the components and tried to turn it on and it turned on but ....... it burned again the high and low mosfets and switch (pq104, pq105, pq103)....
                            05-23-2024, 10:03 AM
