Corsair RM650 ATX, possibly struck by lightning
  • Sam “Captain” W. C
    • Jun 2024
    • 9
    • United Kingdom
    Just starting out in electronics repair and teaching myself as I go.
    I have here a Corsair RM650 ATX PSU, which I'm treating as a learning project that if successful may be used in my PC.
    Fuse was blown, probable power surge from lightning, followed the circuit and found, a dead relay and all the diodes and resistors around the bridge rectifier shorted. Rectifier and MOSFETs seem fine on the LCR.
    Also found these tiny diodes on the other side, a few shorted, the rest seem fine. But they're not all marked as Zener on the pcb. So I'm unsure what these should be replaced with.
    Any tips on how to proceed?
    Fairly sure the surge didn't make past the transformers, but how could I make sure?
    Just don't want to miss anything before I power it on.
ID:	3288999 Click image for larger version
    • Jun 2024
    • 9
    • United Kingdom
    Also I'm having trouble identifying these resistors as I'm unsure which way to read the colour code.
    The left one is either 28M or 16.8k.
    fairly certain the right ones are 10k, but the black tolerance band is confusing me.
    fairly sure there all 2W, they're 17mm long, 6mm diameter, 2mm wire, am I right?
      • Jun 2024
      • 9
      • United Kingdom
      OK so after some more work, the question I'm left with is how to determine the voltage rating of the smd diodes, as they have no markings, they are 5mm long by 3mm wide.
      Ideally without probing it when connected to mains.
      • harp
        • Jun 2022
        • 648
        • Planet Earth
        am I right?
        No.
        Left - brown blue silver red, so 16x0.01ohm 2%
        Right both - brown black silver gold, so 10x0.01ohm 5% --- 0.1 ohm
        You literaly see resistive wire wrap arround package few times, there is no way that is 16k or 28M... nor 10k. Always be descriptive when asking for help, how you see that...
        Do not rush... learn about basic component and measuring, practice desoldering soldering on some scrap board.
        What you mean dead relay, how you test it?
        The resistors dont shorted, and around bridge rectifier, is there another diodes and resistor?
        What LCR and how you tested it?
        I see, you are desoldering a bunch of components from pcb at the same time... must say that is not a way to troubleshoot psu. If you are just experiment and it is irrelevant to repair, it is fine, but if you ask to learn a procedure, or expect to some guide you and give you a tips, this is no-no category.
          • Jun 2024
          • 9
          • United Kingdom
          OK thank you, that's a huge help already, I was thrown off by the black ring at the end.
          And don't worry, that's exactly what I'm doing.
          And I just powered the relay and got a click on and off. So I was wrong there.
          And I assure you the resistors are short, and they came from the negative DC pin of the bridge rectifier.
          There are diodes on AC pins of the bridge rectifier both seem fine,
          Plenty of resistors too, which I'll go round and check tomorrow. It's getting late.
          I used a LCR-T7 to test the MOSFETs, out of circuit, and they showed up matching their data sheets.
          Yeah its not essential that the PSU is fixed, I'm just using it to learn some stuff, be nice if I do manage to fix it though.
          Thank you for your answer, really appreciate it.
          • CapLeaker
            Leaking Member
            • 8351
            These resistors are so low in ohms they appear as short and belong that way. Different it would be if they have have resistance or open, because they would be out of spec. Your PSU would starve of power or have no power, the resistors would be baking hot and blow (open).
            • harp
              • Jun 2022
              • 648
              • Planet Earth
              Black ring on the end is probably thermal coeficient or so.
              I assure you, that resistor on picture is not shorted, it is low ohm resistor, it can not have lower resistance that what have wrapped wire on him. And wrapped wire have 0.16 ohm.
              Not all dmm are precise in low resistance reading. But, check on yours T7 transistor tester, what value measure for that resistor?
              BTW, just now notice... your dmm leads are wrong connected. In attachment it is correct. Black leads always must be connected to COM port, it is refference point of all measurements.
              When you do so, connect strongly together both leads (red and black) and write down measured resistance value of shorted leads, that might be like 0.3 ohm to 0.6 ohm... this is pure resistance of your leads, that do matter in low resistance measurements.
              Now, test again your 0.16 ohm resistor, it should measure say about 0.8 ohm, and substract value of your shorted leads, and your measure will be close enough.
              So, inspecting your board...
              What is out:
              - input wires
              - input fuse
              - graetz
              - power resistors x6?
              - TO220 x4
              - heatsink
              - standby transformer
              - and few other unknown parts...
              I hope that you write down from where to where is some component tooked, orientation, value...
              About your questions for diodes: there is few common type of diodes:
              the rectification diodes, for mains, voltage drop is like 0.6v
              The switching diodes, have voltage drop about 0.3v
              Small signal diodes
              And zenner diodes
              You are about a small signal diodes, it is for general purpose small glass signal diode like 1N4148 simmilar characteristic. They have rated for relatively high voltage but very small current. The marking ring is easy varnish by scratching, touching etc. due to slippy glass surface, they are marking on catode side.
              Switching diodes work on high frequency and current, but lower voltage, to about 50V or so, called schottky diode, have smaller voltage drop
              Do not mess arround with this small glass diode because they may be zenner which is crucial for some regulation circuit. If you spin it around you may burn something else or waste hours and houres to find fault.
                • Jun 2024
                • 9
                • United Kingdom
                Ok, I'm with you now, apologies for being dim.
                tested the resistors with the T7 and they show up as you said they would.
                So that just leaves the several shorted diodes, one 600V rectifier diode (1N5406), and the smd ones (LL34)
                Thanks again for clearing things up for me.
                • Dvsr
                  On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                  by Dvsr
                  Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                  I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                  After replacing the caps I started testing out the speaker. It seemed...
                  09-10-2025, 10:20 AM
                • caspian
                  What Zener Diodes on a Linear Power Supply
                  by caspian
                  Dear members,
                  I have a linear variable power supply with unknown brand name that I used for voltage injection.
                  Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                  In addition, I discovered that its zener diodes are defective.
                  I can replace the burned transistors.
                  But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                  Therefore, I cannot replace the zener diodes.
                  I do not want to test the zener diodes in a test circuit to discover their model or value.
                  no schematics are available...
                  05-26-2025, 12:38 PM
                • lolich112
                  RTX 4070 Ti GAMING X TRIO 12G All displayports failed after lightning struck
                  by lolich112
                  Hey, I have this GPU (MSI GeForce RTX 4070 Ti GAMING X TRIO 12G). After a lightning struck all dispaylports don´t work anymore but the one hdmi does in fact function properly. Has anyone a suggestion, what the error may be? Is it the GPU core itself that is damaged or is it a simple replaceable chip that is fried?
                  10-01-2023, 10:51 AM
                • Redrebel10
                  Samsung Ln52B750U1FXZA struck by lightning
                  by Redrebel10
                  Old friend was throwing this away after lightning struck their house. Standby power light is on but no backlights will come on. However when I disconnect the main board from the power boards, the backlights immediately come on. This leaves me to believe problem is with the main board. Any help would be greatly appreciated.
                  09-17-2021, 02:58 PM
                • alltvrepairs
                  Philips 50PUS8555/12 Power supply fault
                  by alltvrepairs
                  715ga018-p01-006-003s
                  Am trying to find a pdf .
                  i have no secondary output voltage. So far done the obvious checked supply on primary caps 320v, supply on power supply ic found 22v and cannot see any burnt components.
                  tried with meter most components like resistors diodes etc.
                  in secondary there are no shorts either.
                  This was struck by a lightning and could see a burn under the air gap capacitor.
                  Attaching the board.
                  Any clues welcome.
                  Tks...
                  08-30-2025, 08:42 AM
