Samsung Ln52B750U1FXZA struck by lightning
  • Redrebel10
    • Jun 2017
    • 89
    Old friend was throwing this away after lightning struck their house. Standby power light is on but no backlights will come on. However when I disconnect the main board from the power boards, the backlights immediately come on. This leaves me to believe problem is with the main board. Any help would be greatly appreciated.
  • Redrebel10
    • Jun 2017
    • 89
    Re: Samsung Ln52B750U1FXZA struck by lightning
    Can anyone give insight on what usually means if you have no backlights unless you disconnect main board from power board
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      Main board failure in my book. I am guessing that if you measure the PSon pin while turning the TV on it will not change. That voltage is generated on the main IC on the main board.
        09-07-2024, 05:50 AM
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
      • JSin21
        Compatibility of main boards between different variations of samsung MU6100
        by JSin21
        Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
        I have Samsung Smart TV UA65MU6100WXXY version DA01
        Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
        11-27-2023, 04:54 AM
      • mrautom8
        Samsung TV UN75H6350AFXZC main board schematics?
        by mrautom8
        Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
        Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
        While relay is on, all voltage rails are present and steady (scoped) on main board.
        I love a good logic puzzle but getting lost without any schematics.
        No shorts on ANY capacitor main board.
        Thermal camera shows 3.3V inductor getting warm instantly but...
        10-19-2025, 06:32 PM
      • Yanleb
        Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
        by Yanleb
        Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
        If they are not compatible why did Samsung give them the same part number to begin with?
        08-04-2025, 11:35 PM
