>>> Troubleshooting Delta Power MAX 500ATX ATX power supply
  • dragon3x
    • May 2024
    • 12
    Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
    that is still quite new, as it worked OK for some months until it failed.
    At the time I was not into power supply electronics; it was put
    aside and a new power supply installed inside the computer. Also at the time
    power supplies were half the price of today's.
    On the PCB there are a D339 and 7500B chips.
    I have found that schematics with these 2 chips (see included file).
    Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
    Some measurements, but first: In my country power is 120 V. / 60 Hz.
    V standby is OK at 5.0x volts
    On the high voltage rectifier diodes I read +166 and -166 V.
    On the high voltage heatsink measure is -166 V.
    So far so good. But there is no "good" anymore. No 12 V., no 5 V.,
    no 3.3 V.
    Inside the power supply box itself there is no apparent sign of
    burnt/defective part (see photo included).
    To debug that circuit what would be the next measurements ?
    ​Thanks for your time and interest.
  • dmill89
    • Dec 2011
    • 2534
    Note: that unit was definitely not manufactured by Delta electronics (the Delta most refer to when talking about PSUs), and looks to be in the 200W-300W range at best. Looks like the typical cheapo generic Chinese unit with a somewhat scammy name (since I don't believe Delta Electronics has ever use the "Delta Power" name, either branding their units just "Delta" or the many OE units they produce for other brands/pc makers, it is probably "technically" not a rip-off but definitely makes it sound like the unit is related to Delta Electronics when it is definitely not). Probably an ancient half-bridge design with super-group (note the one output coil) regulation (which tends to be rather poor). The 4-diodes for a bridge rectifier tend to be a weak point on these but if you're seeing voltage on the primary that likely isn't the failure point here. Given this unit likely lacks anything in the way of overcurrent protection if it was ever loaded anywhere near its "rating" it is likely that something was overloaded and failed. You can start with testing the primary switching transistors, then secondary rectifiers, and of course caps. The almost total lack of input filtering means that any kind of surge or "dirty" power could have also cause damage.
      • 31259
      check the 120/240 switch is working properly,
      it has a voltage-doubler design and should be pushing well over 200v
      • harp
        • Jun 2022
        • 643
        • Planet Earth
        What is resistance of 12, 5 and 3v3 output?
        If you find it shorted, look the diode on secondary side, often fails.
        If it is not shorts then for any reason switching do not work, maybe faulty mosfet or failure of poweron signal circuit, or drivers.
        Regardless to Delta, I think that all of them have mandatory their logo on pcb board.
        The heatsink looks so thin...
        • dragon3x
          • May 2024
          • 12
          Hi, @stj: the voltage switch has been removed and a jumper wire soldered on the pcb for the 120 V. selection.
          Here are power transistor voltages on the high-voltage heat sink.
          In front of these transistors, from left to right:
          Q1-Pin 1: -163 V.
          Q1-Pin 2: +163 V.
          Q1-Pin 3: -163 V.
          Q2-Pin 1: 0 V.
          Q2-Pin 2: +163 V.
          Q2-Pin 3: 0 V. (connected to Q3-Pin 2)
          Q3-Pin 1: -163 V.
          Q3-Pin 2: 0 V. (connected to Q2-Pin 3)
          Q3-Pin 3: -163 V.
          Heat sink vltage: -163 V.
          @harp: I will test resistance of 12, 5 and 3v3 output in my next post.
          • dragon3x
            • May 2024
            • 12
            Hi, harp : With power supply not connected to 120 V., resistance to ground is:
            for 12 V. : 230 ohms
            for 5 V. : 22 ohms
            for 3.3 V. : 15 ohms
            Hoping this will help somewhat.
            • harp
              • Jun 2022
              • 643
              • Planet Earth
              It looks ok, I have simmilar atx 450w with 12v/250R, 5v/25.5R and 3.3v/25.0R...
              Ok, offline check first:
              - main mosfet, to confirm thre is no short on them
              - 7500 and 339, check supply rail to this chip there is no short
              Online mains check, with 60w current limit bulb in series:
              -can you describe exactly whats going on output when it is connected to mains
              -fan spins, a even little?
              -if you grounded power-on is something changes? Is steady 0.00v or fluctating from where to where?
              So you say (purple) standby 5v is ok, what is voltage on green wire?
              - voltages on both IC supply pin, is steady, fluctating...?
              What dmm you have, can you measure whats going on gate of mosfet?
              • PeteS in CA
                • Aug 2005
                • 3583
                • USA, Unsure of Planet
                As dmill89​ pointed out above, that is not a Delta Electronics//Delta Products power supply. Delta would not use wimpy heatsinks like that for a 500W power supply, and probably not even for a 250W unit. Delta doesn't install jumper wires where common mode inductors belong. Delta would NEVER use 1KV DC or 2KV DC ceramic caps instead of agency-approved Y-caps! Never!!! That output filter section is pretty pathetic. The input rectifiers are pretty small, and the output transformer core would not be good for much over 250W. I would not apply power to the thing without removing those unsafe caps in the Y-cap locations, but I think the 200-250 W estimate above is probably correct.
                The 7500B is a clone of the venerable TL494. It's a decent enough voltage mode PWM, but Delta Products uses 384x series current mode PWMs or custom ASICs in its consumer-grade power supplies. The venerable LM339 is a very decent quad comparator, but Delta uses ASIC or dedicated supervisor ICs.
                Do each of the input electrolytics have ~165V across them? Or about half that. If the latter is the case, then voltage doubler is not working or the jumper you think hard-wires it does something else.
                PeteS in CA
                • dragon3x
                  • May 2024
                  • 12
                  Hi, thanks or replying
                  PeteS in CA : From my initial message:
                  "On the high voltage rectifier diodes I read +166 and -166 V. "
                  "On the high voltage heatsink measure is -166 V. "
                  harp : With power supply not connected to 120 V.:​
                  There is no shorts on the 3 power transistors on the high voltage side.
                  There is no shorts on the LM339 and 7500B ICs
                  Yesterday while I was doing some measurements a small wire fell on the PCB.
                  Result: 2 resistors 1/8 watt are broken and the 5 V. standby is gone. To repair
                  I need a schematics. The included "DeltaPower_MAX-500ATX_Schematics.png"
                  in my initial message at first seemed OK but now I need precision and something
                  doesn't work in the schematics resistors around the 2 ICs compared with the
                  MAX-500ATX psu.
                  If KA7500B is a clone of the TL494 then I will search schematics with TL494 + LM339.
                  This is the situation for now and I continue my detective work on this.
                  • dragon3x
                    • May 2024
                    • 12
                    Hi, this is an update about that Delta Power MAX 500ATX project.
                    After searching on internet I realised I could not find the exact schematics needed. Some "seem" to have
                    the same exact topology and same parts but, looking more attentively, many parts are not identified.
                    Others are well documented but the topology/circuit itself is not the same.
                    Then I tought why not remove/unsolder the resistors, capacitors etc. and after that build a new PSU from an
                    exact schematics that I have found. Anyway I cannot repair the actual Delta Power, what choice do I have ?
                    So I started that "revised" project. Suprisingly, removing the parts was easier than I tought in the beginning.
                    Once done, I began the reflexions about building the new schematics in the Delta Power box. Then I hit a wall:
                    where to begin with, how to adapt the PCB to the new circuit, are the Delta T1, T2 and T3 transformers
                    appropriate for the new circuit ......... Suddenly there was too many questions and not enough answers.
                    Then I tought (again) why not undertake a review of the recent/modern SMPS ICs that are available on the
                    market, the idea being they are surely better than the archaic chips in cheapo power supplies. The best of
                    them are protected against whatever can happen: overvoltage, undervoltage, short circuit, open circuit,
                    over temperature, overload, ...... Also, for a typical circuit, parts count is lower. On the negative side the
                    learning curve can be steep.
                    Example ICs: Infineon ICE5xSAG, ICE5ARxxxxBZS, NXP TEA1623P, TEA172x, Onsemi NCP1362, UC384xA,
                    ------------------ST Microelectronics 6566B, Texas Instruments UC3842, UC3843 (not a complete list).
                    This is where I am now. I plan to start with Infineon, we shall see. This is not a short term project and I hope
                    it won't become a long term adventure. At least it is looking forward with new generation SMPS, not backward
                    to outdated electronics.
                    I will post a project update from time to time.
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
                    • Gentian
                      Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
                      by Gentian
                      I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
                      09-27-2025, 11:03 PM
